Question about Magellan Maestro 4250 GPS
Magellan Maestro 4250 wont charge
Sometimes i can put it to charge through the usb but it wont turn on like normal. It also seems a little warm.Normally I hook it up and it charges over night and it will last all day.Is my device defective?
  • dresters Dec 27, 2008
    i have the same problem but my question is, does the magellan need to be on when charging or can you have the device turned off and charging?
  • Anonymous Mar 30, 2014
    I had put gps to charge over night and it don't turn on?
  • 28 Answers
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Posted on Dec 24, 2008
My magellan stopped holding it's charge. Battery needed replacement.
Posted on May 29, 2010
If sometimes it charges through USB and sometimes it doesn't, and you are using the *same* charger every time, then it sounds to me like the unit or charger may be defective, because whatever behavior you get, you should get every time.
It does not charge from a USB connection to a computer. When you hook it to the computer, it goes into its computer-docking mode, where it can't be operated, but you can access it and update its software from your PC (using the Magellan Content Manager program).
It does charge through its USB port from an AC adapter, as long as the adapter provides enough power (1 amp). If you're using some other AC-USB charger (i.e. from some other device), which does not provide enough power (say, 500 mA), the unit will not charge. It will sense that something has plugged into its USB port, but not seeing the needed power to charge, it assumes it's plugged into a computer, and puts up the computer docking screen. It is possible that this might be bad for the unit and/or the charger. And it is cerrtainly useless, as the unit is neither charging, nor capable of being operated.
And of course, it also charges through the car charger.
Posted on Jan 10, 2009
Once I updated my Magellan Maestro 4250 the beginning Magellan screen comes on & the bar at the bottom advances like its loading then it stops and freezes. I've tried reseting it without success...
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Maestro 4250 GPS
My magellan maestro 4250 is taking longer to reroute than usual, what may be going on?
Try resetting the unit, there is a reset slot at the bottom of your unit and buy resetting it, sometimes this helps.
Good Luck
Apr 03, 2010 | Magellan Maestro 4250 GPS
I updated my magellan 4250 to v4.86 and now it will not work with the car charger. Screen states that USB is connected and I should follow prompts on PC screen. It work fine before the upgrade.
turn it on and hook it back up to the computer and once it has installed, use the safely remove hardware wizard to remove the 4250 from your computer, then plug it into your car again...if that fails, turn it on then try the reset on the side (little pin hole) use a paperc clip to reset it.
if you need further help, just reply to this post.
bill
Jan 20, 2010 | Magellan Maestro 4250 GPS
My magellan maestro just stop working it will not turn on
there may or may not be anything wrong with it, but id be surprised if there wasnt. this model is by far the worst magellan has ever put out, IMHO, it is plagued with problems right out of the box.
wont start,restarts,wont charge because of the faulty usb connector,freezes,white screen,problems with the digitizer, the screen become littered with dead pixels and on and on.
anyway, charge your 4250 good for a few hours via the usb cable to your computer, the press and hold the power button for up to ten seconds or until it starts, if that fails, let me know and ill give you something else to try.
good luck
bill
Dec 21, 2009 | Magellan Maestro 4250 GPS
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
Jul 19, 2009 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Help
my gps 4250 would show the blue magellan screen (sometimes the map) the it would completely crash! I paid 500 bucks 4 this ****- plz give me some answers!!!!
Jul 25, 2008 | Magellan Maestro 4040 GPS Receiver
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 GPS Logo
2,787 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
