Computer not recognizing plug and play printer
Tech from Canon couldn't solve the issue.
Discovered that inf file was missing in Windows XP
  • 31 Answers
Maybe the system files are corrupted. my suggestion, format the drive and install a fresh copy of windows xp.
Posted on Dec 03, 2008
I cannot get the printer Canon MX870 connected to the computer network. I am running windows XP I have it connected to the home router but when I put in printer name while adding the printer on the...
You cannot just add network printer on Windows XP without the printer software. You can only install it on Windows 7 with no software.
You need to get the canon MX870 software and run it on the computer you want to print files from. 'Before you do it, make you have already setup the printer to connect to your router and also make sure that it is connected to your router before you run the software.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Select Windows XP (NOT WINDOWS XP 64) then download and install the first file "mp68-win-mx870-1_04-ea24.exe" Run it and it will show you options. Choose setup wireless there you go! Make sure you are connected to the-same router the printer is connected to.
Please rate 4 stars if this solved your problem. Thanks
Apr 26, 2011 | Office Equipment & Supplies
Hp photosmart c4680 will not scan I'm getting file missing error. The HP tech said I'm missing a usb file from windows! Is tere any way to retrieve that file?
You can go to http://www.infdump.com/inf-files/U_1.html and downlaod the missing file and update the same.
This will require technical expertise and if you cannot do that yourself then call the manufacturer tech support ( 1-800-474-6836 toll free).
Need to mention more specifically which file is missing.
Jul 13, 2010 | HP Office Equipment & Supplies
My vista does nnot recognize one partition on my
1. In the run command (Start menu bar) type "regedit" to bring up the Registry Editor.
2. In Registry Editor, navigate to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
3. In the details pane, double-click DevicePath.
4. Add a semi-colon to end of the existing text, and then add the path to %SystemRoot%\System32. The result should be similar to: %SystemRoot%\inf;%SystemRoot%\System32
Do not remove the %SystemRoot%\inf file path from the DevicePath registry entry.
5. Click OK to save the new value, and then close Registry Editor.
6. Delete “INFCACH.1” FROM C:\Windows and C:\Windows\Inf Directories (if it exists)
7. Ensure that there is a copy of the usbstor.inf file in C:\Windows\Inf
If there isn’t – follow the below steps:
a) From another Vista system (copy it out of another Vista system and copy it directly into the C:\Windows\inf directory
OR
b) From the problem machine, run Command Prompt ( as administrator). From C:\ do a dir usbstor.inf /s . Wherever the file is found, go to that directory and copy all the files located in that directory to C:\Windows\inf directory
8. Open device manager, uninstall all unknown devices (right click, uninstall) so they all disappear from the list
9. Reboot the computer
10. Plug the device in (the drivers will now install and the device will be usable!)
Mar 06, 2010 | Electronics - Others
I have a Canon BJC-2000 printer which worked with my old computer. I now have windows xp and I would like to know if I can use it now Thanks
Wow... that printer is still working after all these years? Hook it and, turn it on, boot the computer and see if Windows XP will recognize it as a "plug and play device", if NOT, you out of luck. Canon does not have any updated drivers for this unit. Good Luck...
Dec 03, 2009 | Canon BJC 2000 InkJet Printer
Cannot install downloaded driver. Windows XP looks for a .inf extension which doesn't exist in the driver files
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-16
Aug 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Logitech M-BJ58 USB optical mouse win xp issue
Hello dcipher,
This is due to a missing Windows file called input.inf. The solution is as follows:
In Windows XP, you can use the MSCONFIG utility as described in the following steps:
  1. Click Start->Run.
  2. Type msconfig in the Open field, and then click OK.
  3. Click the Expand File button.
  4. Type input.inf in the File to restore box.
  5. Type the path of the Windows XP .cab file where you want to restore the file from in the Restore from box. If you don't know the patch, click the Browse From button to locate the Windows XP .cab file.
    Note: The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  6. Type C:\windows\inf\ in the Save file in box. This assumes that Windows XP was installed to the default directory. If Windows was not installed to the default directory, you will need to adjust the path to point to the correct directory.
  7. Click the Expand button.
  8. Click OK. If you are prompted to restart the computer, click Restart.
After extracting the file and restarting, try installing the mouse software again. You should no longer see this error message.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free holidays, meals, shopping and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Apr 24, 2008 | Logitech Wheel Mouse Optical
Do not work with windows vista
Yes, it is because the INF file was written for windows 95 or later. That "or later" driver was probably released before Vista. You can get a Vista driver here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368
Aug 25, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
