Question about Canon PIXMA MP780 All-In-One InkJet Printer
Colors are not printing out true.
Although my ink levels show that I have plenty of ink, the colors are not printing out true. For example, my red color prints out brown, and my yellow color prints out lime green.
Also, anything that I print in black appears straffed (not solid). To correct this I have to do a maintenance cleaning each time. In fact, I have done a complete maintenance check (i.e. nozzle check, cleaning, head refreshing, roller cleaning, etc.) several times, but to no avail.
Recently I replaced my cyan ink cartridge (6-C) with an Office Max ink cartridge equivalent. I'm wondering if that is "gumming up" the works.
Can you make recommendations as to what may be causing this problems and how to address it?
Thanks,
Thom
  • 1 more comment
  • Anonymous Dec 09, 2008
    I have just replace the yellow ink with the same brand that I have always use. My brown is now lime green and the dark green is a bright green.
  • Anonymous Dec 19, 2008
    i have a canon printer i900D series photo printer. my magenta color comes out brown. how can i get it to print red. it's christmas! help! gotta know now. Ruth.
  • Larry Linch May 11, 2010
    It has been my general experience with ink jet machines that anytime you use an offbrand, generic or refill cartridge you are taking a gamble with the results. The very first thing I would try is to make sure all the inks in the machine are genuine canon. If that doesnt work, let me know.
    Larry
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Posted on Dec 04, 2008
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
My Canon MP210 never prints photos correctly! The colors come out like the right color but very incorrectly. Basically, the photos all have very severe color management problems. APparently the printer has...
Have you heard of Wysywig? What you see is what you get?
Well on color pictures on you monitor you get wysinwyg what you see is not what you get. Monitors are backlit, so colors are much more vibrant than what a printer can generally deliver. Explore the printing properties of your priinter as there are adjustments that can be made to enable better quality and true to color prints. The paper you use to print out your pics is also important in producing color that is close to original.
When you view your pics on screen try adjusting the color hue to the point it becomes overcolored and try a few experimental prints to see what level of the slide is needed to be used to achieve a brighter more vibrant picture. I would also like to say that the Canon 210 , whilst it is a very good printer, is at the cheaper end of the photo printer scale.
Talk to your ink and paper supplier, they can often show you or recommmend printers that are much higher and more accurate in delivering brighter and true to color photos.
Please rate my help++++Thanks for using FIXYA
Aug 04, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Feb 08, 2010 | Brother MFC-440CN InkJet Printer
All my photos have a heavy red tint
Be sure you have plenty of all the different inks and that the print head is clean and functioning well. If you are low on one of the inks the colors can be off.
If you have plenty of ink then on of the color print heads may be clogged and preventing that ink from flowing. A few cleaning cycles will hopefully fix this.
Also realize that different inks will render different color reproduction and will especially look different from what you see on your computer, unless you have special software to correct for this.
Dec 19, 2009 | HP Photosmart D7460 Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Color
Our I 560 S prints green and no other colors. All cartridges appear to hav e plenty of ink in them.
Thanks, Becki
Sep 17, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
492 people viewed this question
old marine
old marine
