Question about Akai DVDP5851 DVD Player
May samsung dvd player does not play any disk i always seen
At screen "the disk cannot be plapyed pls check the disk and inser t it again"
i try to insert again but still thesame message appear to the monitor
    Genius:
  • 1,550 Answers
Try with other disk . May be that particular disk is damaged .
If your problem still exists you need to clean the lens with lens cleaner kit .
Hope this helps.
Posted on Dec 03, 2008
Hi, I have a Samsung Blu-Ray BD-C5900 and I it does not play all regions DVD's, I would like to play all regions on m Blu-Ray, is there a code that can set this up?
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2-9
You should seen "9" on right of screen.
Good luck.
Apr 01, 2011 | Samsung BD-C5900 Blu-ray 3D Player
Have the Samsung BDP1590. The screen only says CLOSE and will not do anything else. Tried the reset instructions but nothing happens. The DVD player is less then a year old. Can someone help me out.
I had this problem when trying to play Avatar and my player locked up. I'll assume you have a disk inside when this happens.
Try pressing the power button to turn it off, then turn it back on again but as it starts press the Open/Close button - you may have to do it twice because at the first press my BDP1500 says "CLOSE" then a second quick press will show "OPEN". Take the disk out, then try another disk. If it's a problem with trying to play a recent disk you should be ok until you try to play it again. Read up on updating your firmware, etc. Good luck.
Sep 18, 2010 | Samsung BD-P1500 Blu-Ray Player
Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
Mar 13, 2010 | Samsung DVD-V8600 DVD Player/VCR
Player won't play some of my DVD movies
have you tried playing them again from "cold start" that is not after 5 in a row ?? are the disks clean and free of dust etc ??
Mar 09, 2009 | Samsung DVD-V1000 DVD Player/VCR
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 02, 2009 | Coby DVD-209
Dvd disc won't play
Maybe the laser lens are dirty and need to be cleaned
Nov 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
DVD Player not working
i have dvd player, but me inser disk. then dvd told me error disk, then me inser another one disk, same reply, waht i can i do?
Apr 03, 2006 | Sony D-VM1 Portable DVD Player with Screen
Akai DVDP5851 DVD Player Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
