Question about Sony MHC-RX100AV Shelf System
  • 2,712 Answers
Most likely a dirty lens or an optical assembly problem.
If its a dirty lens, the issue can be easily rectified by using a CD lens cleaner, available from nearly any electrical store.
If cleaning with the lens cleaner did not help, then it could be a major issue. Try unplugging the system from the power source for at least 15 minutes and replug and see first. If it works, great! If not...
If the lens has become opaque or scratched, or there is a problem with the assembly, then the only solution is to take it in for servicing. Mind you, this can be a pretty expensive repair, so you'll have to decide between getting it repaired or purchasing a brand new unit altogether...Shop around for repair costs and then decide which route to take..
Posted on Dec 03, 2008
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | Audio Players & Recorders
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
2008 Altima with factory nav/cd changer. 2 CDs were stuck in the changer, which I was able to remove. However, the disc indicator lights remain Green for discs 1 and 2 even though there are no discs in the...
unless you can repair the cd unit its gonna be a replacement.
or you could transfer all your cds to mp3 and play them through your fm radio........until you sell the car
Sep 11, 2010 | Nissan Altima Cars & Trucks
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD player fails to read CDs Sharp CD BA150 3 Disc Rotary Charger System : Issue; CDs that are loaded into the trays do not read/play, even though they did previously. Most disks will spin a little while...
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Jan 25, 2009 | Audio Players & Recorders
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Most CD players that would not play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door (if it's got one) once the disc is loaded;
5. relube, clean as necessary but that would require pulling the unit out of the dash.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Thank you for using Fixya.
Feb 14, 2008 | Car Audio & Video
Cds won't play
usually then its somthing internal, my guess would be a laser pickup, as those are most common t go out
Jan 03, 2008 | Alpine CHM-S665RF 6-Disc CD Changer
190 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
