Question about Maytag Atlantis MDE6400AY Electric Dryer
Maytag electric dryer will not run
I have Maytag electric dryer and it won't run. The light is on inside but the dryer will not turn or run
  • v_goodridge Dec 03, 2008
    It is making a humm sound when you press the start button
  • Shane Hays May 11, 2010
    Hello v_goodridge,
    Is the dryer making any noise at all?
    Scholar:
  • 82 Answers
Just like the other tech. said, it is most likely your belt or a bad motor. The belt is a pain in the neck to replace because the top, the back and sometimes the front need to come off.
Posted on Dec 03, 2008
  • 25 Answers
Belt around the drum is broken. The light you see is the glow of the heating element. No air flow will cause heater to get red hot. Danger!
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
Dryer control board does not work. no lights nothing, but the dryer inside light works.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone bad?
i would start with the door latch if its broken the dryer will think its door is open and wont turn on
Apr 21, 2010 | Maytag MED5700TQ Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
It does not turn on, no electricity gets to the control panel
check the door switch. it should click when you operate it with your finger. that is a common and easy fix. good luck
Nov 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whilpool Dryer Won't Run
you have a bad saftey swith inside te dryer this cost anyware for $8.00 to $ 15.00 for the part
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
254 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
