Question about Hotpoint Ultima WF860 Front Load Washer
Noisy spin loose drum
Hi I have a reasnobaly new hotpoint super silent ultima machine. During the spin cycle its so noisy and loud you have to leave the room, the feels that it is slightly loose as when you move it with your hand it makes a knocking sound. hope someone can help thanks Rob.
  • Redmist Apr 10, 2008
    I have a Hotpoint Ultima WF860 Super Silent machine that makes a KNOCKING sound when it starts the Rinse spin.
    On the final rinse spin, the knocking is still loud, but the whole machine vibrates a great deal.
    I have checked that the machine is level, and also have taken he top lid off and have not found anything loose.
    Any ideas please?
  • Anonymous Mar 23, 2014
    When it spins its super noisy
    Sergeant:
  • 389 Answers
The model you have you will not be able to change the bearings and inner spider you have to buy the whole inner and outer drun complete very expensive
Posted on Nov 02, 2011
Drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Posted on Feb 02, 2007
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
My HOTPOINT ULTIMA WASHING MACHINE wt960 is very noisy on the spin cycles...is there a need for oiling or what else can I do..?
It could have an imbalnce in the drum because the load is uneven, or your machine could be uneven on the floor,, try checking for the level of your machine
Apr 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
During spin cycle started making loud noise now drum feels loose
during spin cycle it makes a lot of noise could it be the bearings that have gone
May 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
891 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
