Question about Epson Stylus 1400 InkJet Photo Printer
I have epson stylus 1400 and when i print out, it has white lines. i cleaned head and check ink and paper settings. but still appears white fine lines. Please help me.
  • 1 more comment
  • robertgenalo Dec 31, 2008
    Yep - Same problem here. It occurs when I print large amounts of color. I have reason to believe that the lines are occurring when the print heads "rest" on the page, before beginning again.
    Any suggestions? The checks all come out clean...
  • kate_design Feb 20, 2009
    I just set up my printer and the first 2 prints were fine, then the white lines started. The files have a lot of color, but was expecting more from an epson. Any suggestions?
  • dogdive Feb 22, 2009
    I'm dealing with the same thing. This printer is right out of the box. I printed a few pages and everything looked awesome. Then I sent multiple pages at once and I've got white/faded color lines running through the page. Regardless of how saturated the color, this really isn't acceptable.
Okay. After some internetz scouring, I found a solution for what I was experiencing. The problem is probably that your print options are optimized for speed and not quality. Check out this link to see Epson's solution: http://files.support.epson.com/htmldocs/pho140/pho14000rf/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Probsolv.5.1.html#1023833
Posted on Feb 23, 2009
  • cthrogmorton Mar 28, 2011
    This is correct. Had the same problem and this solved it.
Epson printer 1400, is printing vertical blue lines through my prints. How can I eliminate them?
If the lines are vertical to the direction of the printhead movement, you need to clean the paper rollers and the small "pizza wheels" of your printer. Also check for any traces of stuck paper in the paper path. I recon you ars not using genuine inks, right? Try to slow down your print speed by selecting a best quality setting.
If the lines are parallel to the printhead movement, your printhead is either clogged our stuck.
Jan 07, 2014 | Epson Stylus 1400 InkJet Photo Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Poor print quality, not fully black with white lines through text/images.
The white lines are caused by some CLOGGED ink-jets that are not spraying the ink onto the paper at the appropriate time.
Start the Epson printer-software, and run a "print-head-cleaning-cycle", to try to UNCLOG those ink-jets.
Oct 17, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Change black ink and now prints with white lines through the words on every other line
It is CLOGGED print-heads that cause the ink to _not_ be sprayed onto the paper, resulting in "white" horizontal lines.
Run a "print-head-cleaning-cycle", using the Epson software installed when you installed the printer.
Aug 28, 2010 | Epson Stylus NX100 InkJet Printer
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
My epson 1400 printer doesn't print
try printing a nozzle check to see if the nozzles are clogged by dried inks that why nothings printing. turn off the printer than press and hold power and paper button together for 3 sec. then release, it will print, if blank, all nozzles are clogged. do a head cleaning. hold the ink button for 3 seconds. wait until the power light stops flashing then print nozzle check again until all lines are complete,
Feb 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson r390 printer prints blank(no text on paper)
Check condition of head first. Move head to parking position (head cleaning position). From outlet pipe of head cleaning mechanics, do suction. It's there is ink, the head is not clog (and the flow of ink is ok). Make nozzle check. If nothing lines appear, the problem is in board (cause you just reset). Using resetter, do initial setting. Good luck.
May 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: support.epson.com try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
328 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
