Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator gear is stripped
The cogs that turn the agitator (top part of clothes mover) have all stripped. I have removed the entire plastic agitator from the middle of the washer. How do i separate the top part of the agitator from the lower part to replace the cogs??
  • 41 Answers
Just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Posted on Dec 03, 2008
Whirlpool F65 6th sense Whitemagic top loader fully automatic - Cloth Mover (Agitator top assembly) slipping - India Model.
HOPE PICS HELP U MAY HAVE BAD AGITATOR COUPLER, BAD CAM DOGS, ETC
SEE PICS
In your case the cam dogs are repalced with this coupler.
Jun 06, 2015 | Whirlpool Washing Machines
How do I remove the agitator from my Kenmore Washer model number 110.24962300 to clean under it as clothes are coming out with flakes of dirt and soap-scum pieces etc. on them?
Follow these detailed step-by-step instructions to help you locate and replace your Kenmore worn agitator cogs:
  1. Before you begin this or any other repair, disconnect the power supply to your washing machine. Either unplug the unit from the wall outlet, trip the appropriate switch in your fuse panel, or remove the correct fuse from your home's fuse box.
  2. Raise the lid of your washing machine, and if your model uses a fabric softener dispenser, remove it from the top of the agitator by pulling it straight up and off.
  3. Pry off the agitator's cap (if there is one) by wedging a small flat head screwdriver into the slot between the agitator and the cap.
  4. Reach into the agitator top and pull up on the barrier cap and its seal (also called a gasket) to remove them.
  5. Use a socket wrench with an extension or a nut driver to remove the stud and the seal that hold the agitator top to the shaft of the agitator base.
  6. Remove the agitator top by pulling it up off the agitator base. Turn the agitator top over, enabling the cam and the worn directional cogs to slide out. Examine the cam for wear, it also may need replacing.
  7. Attach each of the new directional cogs to the cam. The small round piece at the base of each 'ear' is fitted into one of the cam's four slots. Your model may or may not make use of a black plastic agitator cam bearing. This cam bearing is used to help hold the cogs in place. If your model uses one, make sure you put it back on during the reassembly process.
  8. Carefully insert the cam and new directional cogs into the agitator top the same way they came out. Place the agitator top over the agitator base. There are tabs on the top of the agitator base that line up with, and fit into, the slots of the cam.
  9. If the cogs fall out of place during re-assembly, you will have to take the cam out of the agitator top again and re-insert the cogs.
  10. Push down on the cam until its slots and the base's tabs snap together.
  11. Insert the stud and seal into the shaft and use your wrench or nut driver to tighten.
  12. Make sure the black rubber gasket (seal) is situated properly in the groove of the barrier cap. Then push the barrier cap and seal down into the agitator past the holes.
  13. Replace the agitator's cap or fabric dispenser, whichever your model uses.
  14. Close the lid of your washing machine. Reconnect the power supply and test the machine to make sure it is working properly.
That should do the job for You. Hope this was helpful
Jan 14, 2011 | Washing Machines
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
Nov 30, 2009 | Kenmore 24622 Top Load Washer
The top agitator does not work. It seems that
This problem is generally caused both by by overloading the machine and time. The kit to repair it is called an "Agitator dog kit" and can be purchased at any parts outlet for likely less than $10.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
Good Luck
Oct 03, 2009 | Kenmore Washing Machines
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Stripped gears
It wasnt necessary to remove the shell. The agitator dogs can be replaced from the top through the lid.
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Agitator will not turn
yes ,,, they are called agit dogs ,,,,, replace and that will fix it
Nov 22, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal De
