Question about Samsung Cameras
I have a samsung L200 camera. the battery charges in camera off the USB cable. The cable has a LED light on the camera end of the cord RED for charging Green for fully charged. Now when I charge the camera the indicator turns yellow and starts blinking. I let it charge overnight but in the morning the yellow light was still flashing and the battery hadn't taken the charge. What does that mean?
  • Anonymous Dec 31, 2008
    What if its a brand new camera? I charged it overnight plugged into the wall, but it would not turn on
  • 2,712 Answers
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
My camera ES90 will not charge, when i plug it in it seems dead
There can be more than one reason:
The battery can't be charged anymore, because it is defect.
The cable you use is defect
The charger you use is defect
One or more contacts are dirty or oxidised
Carefully check all contacts on the battery, in the camera the battery compartment but also the USB slot, where the charge cable goes in. The contacts should be clean and shiny. No contact should be bent. Cleaning with a dry cloth or cotton swab.
If the cable to charge is defect it is more difficult to detect. Only when you have another apparatus that can be connecter with the same cable, you could check if your cable is still in working order.
The charging source can be defect.
If it is a charger, you plug in a wall socket, check if you can use it to charge something else. If you put it in a PC, also check if that USB port can deliver 5 volt with enough current.
I do have a little gadget, from the beginning of USB and LED lights. An USB plug with a small cord and a LED light on the end of it.
You could use it as a reading light on a laptop. But it showed very helpful to show if a charger or a USB plug on a computer still is delivering 5 Volts.
I hope you find the culprit.
May 26, 2014 | Samsung ES90 Digital Camera
I am trying to learn about the different coloured lights on the USB cable of the samsung L200 digital camera, to start with looking at this website i learnt the orange light meant that the camera is...
you should change either your battery or your usb cable when an orange light blinking on the usb cable indicator. .maybe one of those accessories was already defect..
Mar 12, 2011 | Samsung L200 Digital Camera
How do I charge the battery for this L200 camera? My daughter received this camera for Christmas, and I can't find anywhere the instructions for how to charge it! Please help! Thanks! Hollye F.
you have the usb cable and adptor right??connect the adaptor and usb then insert it to the camera then plug in to the ac line..but takenote.,the battery was inserted tot he unit..
Feb 20, 2011 | Samsung L200 Digital Camera
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full light means that unit still charging.
Jan 28, 2011 | Samsung L200 Digital Camera
My Samsung L200 does not turn on anymore while everything is at its place, And when I connect to any USB port, it shows a red arrow sign blinking on its cabke. Nothing else. Please help
It may be the battery has failed or isn't charging, have you charged it? Try taking out the battery and connecting to usb, does that change things? If so you should charge or replace the battery.
Jan 27, 2011 | Samsung L200 Digital Camera
Can i use a usb to charge my l200 samsung camera?
No you cannot use USB to charge camera, as it doesn't support USB charging.
Apr 03, 2010 | Samsung L200 Digital Camera
USB Cord
try changing the USB cord to avoid purchasing one, bring your camera to your retailer and ask them if you can try to charge it there, if it does you have to purchase a new USB cable through if the camera is still in warranty, you can try to call samsung and ask them for a new USB cable
Mar 19, 2009 | Samsung L200 Digital Camera
Charging the battery for L200 Samsung
You should have a USB cable that came with the camera, There should also have been a USB to AC adapter, you plug the adapter into the wall, and plug the USB cable into the adapter and the camera. You can also charge your camera by hooking it up to the computer it will charge the battery via the USB cable.
Here is a link to the Quick Start Guide and user manual for your Camera
Dec 29, 2008 | Samsung L200 Digital Camera
Samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Aug 20, 2008 | Samsung L200 Digital Camera
I have a Samsung P800 camera. I'm currently trying to charge it but the light on the charger chord is flashing orange and it doesn't seem to be charging. Please help.
Ok. I have the samsung l200 but the cameras are very similar. I had the issue as well. When I plug it in it flashes red once, green once, then orange consistently. It would not charge the battery.
The fix was really quite unexpected. I did two things not sure which fixed it.
1. slide the cable into the camera slowly until the light turned red once, then pulled it gently in and out a few times.
2. as i plugged it in, I tried to angle the plug side to side sliding it to the left and right on a diagonal. I was hoping the pins would be touched differently when I did this which might reset something.
not sure which of these two things corrected the problem, but the camera is now charging.
Aug 12, 2008 | Samsung L200 Digital Camera
Cameras Logo
403 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
