Question about Dryers
Kenmore Electric Dryer wont start or runs only occassionally
Model 68942891.
Sometimes runs and dries like nothing is wrong.
Sometimes shuts off within a few minutes.
Someitmes won't start.
Never know how it is going to act, but when it refuses to start...it really refuses.
Drum light always works. When it does start, it heats properly on all settings.
Read lots of posts, but almost no solutions. Just complaints that Sears does not care bout this problem with their driers.
  • jkirkpat Dec 20, 2008
    Yes, Sir.
    Fixed the problem.
    Found a Whirlpool even heat control board online.
    Solved the problem with a 10 minute installation.
    Thanks very much.
    Sergeant:
    Champion:
  • 291 Answers
Sound like you have a microcomputer problem / some calls it a even heat board ,,,, it will cause the problems your having / if need help on part contact me and i will see if i can help on part / larryyb
Posted on Dec 05, 2008
Hiow old is my Kenmore Dryer 110 62952 100 It has heat; starts to dry; then stops. Sometimes it finishes drying a load and sometimes not.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Kenmore 62802 Electric Dryer
I have a Kenmore Elite HE4 dryer model 110.95876400. Its running but no heat is coming out and clothes wont dry.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Dryers
My kenmore elite HE4 electric dryer is making a screeching/high pitched noise. It would dry the clothes, but I can't stand the noise. Before the noise started the dryer would occassionally not start if...
Hi- The bearing(s) might be worn or the drum wheels sticking but if it is not starting sometimes you most likely have a motor issue. You'll need someone to come out and take a look at it.
Sep 24, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Electric Dryer
When you first start out with a cold dryer the dryer runs fine, then when you start a second load if wont?
It sounds like you motor is overheating, Your dryer probably needs to be cleaned, taken apart and all of the lint build up around motor removed. also so clean the venting and weather hood outside.
May 23, 2008 | Kenmore Dryers
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
102 people viewed this question
Top Dryers Experts
