Question about Bose Lifestyle 18 System
Center speaker static noise
Bose lifestyle 18: center speaker has lots of static when cbl/sat setting utilized. Issue not present when viewing dvds.
changed rca cables (wht/red) problem still exists.
please advise.
  • 52 Answers
Sorry sp106s, you have to take that to bose service center.
Its a complicated problem. Something is wrong in the amplifier
section inside your sub box. Only authorize servicemen can
open it, not any tech'n can.
Good Luck
Posted on Dec 14, 2008
  • Eric Hiller
    Eric Hiller Jul 02, 2016
    Well I opened it , can you elaborate on the repair that needs to be done? I fixed the display but I still have this issue with my amp section
I have a Bose lifestyle 38 and whenever I watch a show with a lot of background sound - ie music in a movie or crowds cheering for sports, it overwhelms the voices of the actors or the sports casters. How...
What makes background sound comes out from Bose lifestyle 38 system is because there is jack cable or a cable that has a jack mouth that brings out a mono sound is being inserted..
Mono cables, when inserted inside a wrong input,it's makes the sound comes out with a background noise just like the one you can hear from it now..it seems as if you are not using the right cable for connection..
To resolve these issue, you will need to use the right cable for connection, by doing these,you will get a clearer sound from you Bose lifestyle 38..
Also it can be from the settings inside the Bose lifestyle 38...So you will need to check both sides to resolve this issue..
You will need to use the manual to know the right cable and the right setting for clear volume..
You can download the user's guide from the below link..
http://www.retrevo.com/support/Bose-Lifestyle-38-Series-III-Home-Theater-Systems-manual/id/524dj979/t/2/
Hope it helped.
Thanks for using fixya..
Aug 15, 2011 | Bose Audio Players & Recorders
DVD and Menu screen color settings are not right. We recently had the local Bose store set up our Lifestyle 48 system and all was well but recently the screeen color, when in menu mode, has changed from...
Jason.... there seems to be a connectivity issue and i could not see any of your messages in the chat box.......
for reconnecting the unit... please refer to this link below
http://products.bose.com/pdf/customer_service/owners/ls18ii_ls28ii_ls38_ls48_install.pdf
the Surround speaker cables have orange RCA connectors at one end and speaker plugs
at the other end with L (left) or R (right) markings
Jul 31, 2010 | Bose Lifestyle 48 System
Bose lifestyle makes loud noise like a build up of
If you still have the speakers that the TV came with hooked up try unhooking the wires to them I had the same problem and it fixed the problem, Good Luck!
Apr 10, 2010 | Bose Lifestyle 28 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
Increase output of Lifestyle 18
apologies mate but what you hear at maximum volume (set volume to 99) is what the system can generate... The Lifestyle system are designed as stand-alone out-of-the box system and like other systems will only perform to their defined level. The only way is by using the AUX out (located behind the DVD/media center and connect either a pwoered loudspeaker or another amplifier (note that the output is fixed line so choose an amplifier with volume setting knob). with multiple loudspeaker of your choice. You may also go and buy expansions speakers from Bose itself
Again, glad to be of service...
Feb 06, 2009 | Bose Lifestyle 18 System
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
Remote Code
codes for bose123
Feb 01, 2008 | Bose Lifestyle 18 System
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose lifestyle 20 static
if you have turned the speakers to a high volume you have to tighten all the screws and bonds that should help
Oct 14, 2007 | Bose Lifestyle 20 System
Bose Lifestyle 18 System Logo
764 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
