Question about HP Vs17 17" LCD Flat Panel Monitor
Our screen comes on fine for about 2 seconds, then goes off
Our screen comes on fine and then goes dark every time after about 2 seconds
  • bpiRE Jan 16, 2009
    My monitor comes on sometimes for a few minutes sometimes only for seconds. then the screen gets slightly brighter then it goes black and won't come back on until i turn it off and back on again then the same thing happens.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Sounds like classic symptoms of capacitor failure.
Old thread, but in case anyone else is still looking for an answer, the problem is probably bad capacitors on the power board. There was a world-wide problem with capacitors in the early 2000's that affected all kinds of electronics. For a good summary/review see https://en.wikipedia.org/wiki/Capacitor_plague .
Make sure the replacement capacitors are the proper size, specs (volts (v) & micro-farads (mf)) and temperature rated for 105°C. Make sure to install them in the proper orientation, they have a positive (+) and negative (-) terminal. I had 3 bad ones but replaced them all. It's actually quite simple and cheap if you have basic soldering skills. If you're not sure, research soldering technique and safety. Be Safe Out There.
Posted on Jan 07, 2016
    Problem Solver:
  • 15 Answers
If this happens before you turn your computer on, then your monitor is automatically saving power. Just turn your computer (the big box) on before the monitor, and it'll be fine.
If this happens after you turn your computer on, you have a power problem. You can either get it fixed, or my recommendation would be getting it replaced.
Posted on Dec 03, 2008
  • waiwai933 Dec 07, 2008
     Hi! If this solution fixed your problem, please click the "Fixya" rating. If it didn't, please click the appropriate rating. This helps me improve my assistance and the time that I can spend here helping people just like you. :D
My Viore flat panel tv comes on for a few moments, then the lamp and temp/standby light flashes and the screen goes dark. The picture is just fine for the first few moments, and then it goes dark. Any
this is caused by a bad connection, or a faulty back light. It is also something you should have a local repair man have do for you if you are not "tech savvy".
Sep 23, 2014 | Televison & Video
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
Red dots on Samsung 51 inch plasma
Usually either the main board or the power board--if set is 6 months old---no warranty?
Mar 18, 2012 | Televison & Video
VERY Dim screen after a drop
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Our monitor just recently stop working correct. It is on fine during boot but once Windows starts up, the screen goes dark after about 2 seconds. If you turn it off and back on, we get a screen again for...
try reinstalling the os.
there might be file corrupted in the system folder,,,
since the monitor runs on start up , we cannot say that it has a hardware defect...
reinstalling or upgrading your windows will help..
Mar 11, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
HP Vs17 17" LCD Flat Panel Monitor Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
