Question about IBM ThinkPad A22m 2628 Notebook
IBM A22m 2628 HF1 (French Keyboard and Windows XP Home edit.)
Could I and how to convert this lap top to English version ?
I would appreciate your comments and help.
Thanks, Frank
Cant find sound drivers for IBM ThinkPad A22m 2628 PC Notebook for XP
You could try this link.
http://www.notebook-driver.com/thinkpad/ibm-thinkpad-a22m-2628-windows-drivers-software/
Jan 15, 2013 | IBM ThinkPad A22m 2628 Notebook
Game display only occupies the center portion of monitor not full screen. Thinkpad A22m w/ windows xp home SP3. Can't get the game screen to display on the full monitor screen.
It is most likely that the game is unable to operate at the resolution that your screen is set at and is compensating by sizing the game window to the required size. You might change you display resolution to a lower setting.
Hope this helps! Rate my solution!
Jan 07, 2010 | IBM ThinkPad A22m 2628 Notebook
My keyboard is typing an è instead of an apostrophy
Microsoft Windows has support for "foreign" keyboards, e.g., French, Swedish.
You've managed to hit left-ALT-SHIFT to switch the "input language" from English to French.
Use "Regional Settings" within "Control Panel" to set it back to English.
Oct 21, 2009 | Microsoft Windows XP Home Edition
Ok i got a ibm thinkpad a22m with win 2000 p3.....under 'network connections" it shows my modem dial up isp...but not a lan connection...went to device manager and it shows under network adapters "3...
When you download the Thinkpad device drivers, they need to be the XP or Vista versions that matches the version of Windows that is installed on your Thinkpad.
Download the drivers from the IBM/Lenevo WEB site, make sure you select the correct model laptop and the correct Windows version of the drivers.
When you run the driver programs they will be unzipped/expanded to the hard drive in a folder c:\drivers. Then you need to open the various folders and run the setup programs to install the various drivers.
NOTE - The A22 series laptops come with various different manufacturers devices (eg. there are a few different wireless model LANs) and if one version driver doesn't work you need to install a different one. It is a bit of trial and error to find the right one.
Jan 18, 2009 | IBM ThinkPad A22m 2628 Notebook
Need sulution for fix Laptop IBM A22m
try an externial mon. if you have display. this could mean the inverter may be bad. try that and see if it works.
Nov 27, 2006 | IBM ThinkPad A22m 2628 Notebook
IBM ThinkPad A22m 2628 Notebook Logo
150 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
