Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 Gas Range Clock Display frozen with only an "8"
The digital clock display worked fine when we moved into the house. At some point, the display went blank, and has been for awhile. Today, secured all the breakers in the house to work on an outlet, and when I turned them back on, the clock display is lit up again, this time just with an "8". Pressing the timer and clock buttons, or +/- has done nothing to change it. Any ideas other than buying a new clock display control unit?
  • Anonymous Dec 16, 2008
    My GE range clock does not work either.
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Posted on Dec 19, 2008
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
GE XL44 Gas Range JGBC15GER2. Can't see clock on stove; very dim. Do I need to replace the clock/timer?
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Oct 18, 2009 | Whirlpool GR460 Electric Kitchen Range
Ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Sep 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The lighrts on the display of my xl44 wont turn on...which controls the oven temp
you have 1 of 2 problems. your range is either in sabbath mode or your clock control is bad. if you have your model number i can get you directions to see if it is in sabbath mode. unless you have your user manual
Nov 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My clock stopped working on the display
The plug on your range may not be completely inserted into the outlet.
Clear all functions and see if the clock unfreezes
After all this, if the clock digits light up, and you still can't use any clock functions, it may be time for a new control panel.
Nov 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
416 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
