Heat pump blows heat half the time and cold half the time
The heat pump heat works normal....until....it will kick on and blow cold air sometimes. This causes a quick temp drop in my 450 SF bonus room area (71 degrees down to 68 in only 2 minutes for example).
I turn it off and sometimes when i turn it on again it works normal and sometimes it doesn't....
Amana heat pump http://www.dnmech.com/lit/20209826.pdf
  • ronmantwist Dec 03, 2008
    Hmmm, i think you may be right....although i haven't noticed the outside unit frosting up....But, something i didn't mention before (in my hopes that it didn't have anything to do with problem) is that this past summer the fan on the outside unit died so i had to replace it. i was in a hurry because it was very hot (95 to 100 F outside and inside - bonus room) and i have someone living up there.
    The new fan i used didn't have as many wires as the old fan so i had to just connect it directly to the power source near the bottom....not using the other connections that were used by the old fan located on the little computer board near the top. This worked great....for the cooling in the summer.
    I think perhaps i bypassed some anti-defrost connections on the outside unit board, and this might be the problem....?
    Here's a pic of the connections before i made the change.
    thanks!
  • ronmantwist Dec 04, 2008
    Its not the right motor, but the closest i could find on short notice....do you know a website/store that i could order the correct one from?
    I'll also check the wiring diagram.......
    thanks for the response!
  • 25 Answers
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Posted on Dec 03, 2008
  • Walter Whitaker
    Walter Whitaker Dec 03, 2008
    Sounds like you hit it on the head. No power going to the fan from wires from board to motor that was there before. There may be a way to jump it, but I would ask a serviceman to see, or get the right motor for it. If it is the replacement motor for the unit, there has to be some way to jump it for it to work. Check the diagram on back of the door, and you may get some help from it.
  • Walter Whitaker
    Walter Whitaker Dec 04, 2008
    Check www.grainger .com They will come closer than anyone else, and they will ship it to you. Their prices are a lot cheaper than a dealer. If you have the old one, get the model number, and you can search to see if they have it.
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
I have a Rheem Gas/Electric AC unit that provides both Air and Heat. Yesterday the heat stopped working... it blows out cold air. We've had some cold temperatures lately (low 20's) but this isn't unusual...
Heat pumps provide good heat until the tempurature drops below 35-40 degrees. After that there isn't much heat to extract from the outside air and then either the gas furnace kicks in or the electric heat strip does the job of heating the air. if you have heat strips, I would check your breakers in your panel and sometimes there are a couple of breakers right on the air handler or furnace. The ones that will be for your heat strip are 220v and will be twice as wide as your normal 110v breakers . Please don't trust a visual inspection as they can look like they are in the "on" position but are indeed tripped. Turn them all they way off and then back on. If the beakers check out you may have an open cicuit in the heat strips themselves and you will need to have a qualified HVAC tech look at your furnace to repair it.
If your furnace is a "duel fuel" and uses natural or LP gas for back up heat then your ten year old rheem probably needs a good maintenance by a qualified service tech. There is a flame sensor to clean, ignitor to check (replaces the old school pilots), burners to clean flue connections to check and much more. ALL manufacturers of any heating apliance recommend yearly maintenance. Most companies offer something for around 100 bucks. I hope this helps.
Rocco
Dec 12, 2009 | Heating & Cooling
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
2006 Ford explorer/No heat /overheating
Sounds like you are either low on coolant, or a head gasket failure.
Nov 18, 2008 | 2006 Ford Explorer Sport Trac
Heating & Cooling Logo
237 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
