Question about Eureka Uno 2998AZ Bagless Upright Vacuum
How to put on a belt on eureka uno bagless vacuum cleaner
How do i take the cover off to replace the belt
  • Anonymous Feb 01, 2009
    where do u put a belt at on a vaccum
  • 22 Answers
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
  • 701 Answers
Here is a link to replacement Eureka Uno belts and to the Eureka Uno manual which has instructions and pictures on how to change the belt:
Eureka Uno Manual and Belts
Posted on Dec 09, 2009
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
The roller does not spin
Hi schrim8...
Your problem is most likely a broken drive belt.
You will have to remove the vacuum base cover, then remove the roller assembly from the vacumm base to replace the belt.
After you remove the roller assembly put the new belt on the pulley inside the vacuum first, then install the belt on the roller assembly and then reinsert the roller assembly back into the vacuum base.
Reinstall the vacuum base cover.
Please take time to rate me
Jul 28, 2011 | Eureka Uno 2998AZ Bagless Upright Vacuum
Replace belt for eureka model no. 3276 avz . we have the belt for it. we want to put the belt on.
The link below will take you to the owner's manual for your specified vacuum model. Page 4 describes assembly guidelines for replacing the belt. The heading for the page is called "How to Maintain Your Vacuum Cleaner." Pictures are also included in the guide. Hope this helps.
http://www.eureka.com/service/manuals/80509.pdf
Jul 09, 2011 | Eureka 3276AVZ Bagless Upright Vacuum
How do I take the roller bar off to replace the belt?
Sorry to read about your problem, I hope this helps you out.
you have to take off that cover plate, that covers the roller bar, it will snap out, or you will need to remove screws, you might see little arrows. to see what screws to remove
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno Model 2999. I need instructions on how to replace the belt.
I think you will find the free manual at this URL to be helpful
http://www.eureka.com/service/manuals/80247.pdf
Oct 13, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Model 8852 bvz belt for beater bar belt is broke
You need to replace it. Here is a link to the belt you need and the manual which has instructions:
Eureka 8852 Belt
Owner's Guide (1.36 MB download)
Dec 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
What type of belt does the Eureka Uno take?
Here is a link to the belts for the Eureka Uno models and a manual you can view which has instructions.
Eureka Uno Belts and Manual
Dec 15, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
My eureka bagless uno vac problem is when I use it the belt gets really hot and starts smoking
try to manually turn the brushroll. if it feels tight then u will need a new brushroll. otherwise try replacing the belt
Jul 13, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Uno 2998AZ Bagless Upright Vacuum Logo
962 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
