Question about Car Audio & Video
Just installed a Pioneer head unit into my Chryster and the speakers have no sound.
    Problem Solver:
  • 22 Answers
Check for a stock amp. If there is be sure to hook up the remote wire to the harness.
Posted on Dec 04, 2008
Pioneer DEH-P6500 head unit doesnt turn on
Check your radio fuse. It is likely if you didn't disconnect your battery terminal that you may have blown a fuse.
About the speaker distortion, you may need to install filters to each speaker. They are not very expensive and can be found at just about any electronics store.
Feb 26, 2010 | Pioneer DEH-P6500 CD Player
My pioneer head unit cuts the audio signal to my speakers
3 things make sure all the speakers in the car have tape to avoid grounding the speakers
next make sure all wires in back of unit are taped
if all that is taped good its the amp over loading use a larger ground wire to fix this
hope this helped
Feb 25, 2009 | Pioneer DEH-P4000UB CD Player
Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Car speakers sound like they are still on
I don't think it would be your speakers. Speakers are only powered by the wires running from the head unit. Does your head unit stay on when your car is turned off? If so, you need an accessorised power source. One that only engages power when your car is turned to accessories. let me know.
Feb 06, 2008 | Pioneer TS-G6841R Coaxial Car Speaker
Brand New Speakers Distorted and not right...
Are you still using the same head unit? You could try to run a short set of new wire to one of the speakers directly from the unit. Had you previously used these speakers in another vehicle...what I'm getting at is that you need to isolate the problem. If the speakers test fine in another vehicle, I would think there is something wrong with the existing head unit
Dec 31, 2007 | Pioneer TS-A1057 Coaxial Car Speaker
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Loud engine noise through speakers
Jadrian - I purchased a DEH-P780MP and have the exact same sound. My suond however increases in pitch throughout the RPM range and is audible when operating the headunit on ACC. I have found this problem to being typical in Checy Sports cars since I can swap this head unit out from my camaro SS into my Mustang Saleen and the sound disappears. The same is true for a swap into my SUV. Never quite figured it out! I think the 12V line from the fusebox or from the battery itself doesn't have "clean" power.
Oct 08, 2007 | Pioneer DEH-P780MP CD Player
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Open Questions:
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
