White line at bottom of display screen getting bigger.
What do I do about a white line that has been getting bigger that runs across the bottom of the screen? It stays on the screen no matter what I am doing.
Toshiba laptop MODEL NO:P SM 40u-01x001 harmon/karmon SATELLITE CENTRINE
  • Anonymous Dec 13, 2008
    I also have a white line at the bottom of my screen and actually two red virtical lines going all the say up my screen in the middle of the screen as well.
If it's still under warranty they should be able to fix it for you. This sounds like a hardware problem. If you don't have a warranty you'd have to pay to get it fixed.
Posted on Dec 03, 2008
White stripes on plasma tv screen from top to bottom all across display, picture is still visible.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Televison & Video
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
Tv lcd screen got knocked know a red line and a dark patch is getting bigger across screen
You have damaged the LCD Display, the cost of those are close to the cost of a new set. One day the manufacturers will put a safety screen on the front like the older projection sets had to protect those screens. When I sell a lcd set I always recommend to the customer to have a piece of Plexiglas installed over the front, especially if it's for the kids room. Of coarse it's a DIY project.
May 31, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
PJ458D Displays Multiple Lines and scrambled picture
White noise-the image you get when you turn your television to a channel that isn't receiving a signal. Sorry, this is an old term for on-air televisions. Its kinda the same image you get when your DirecTV signal gets scrambled during a thunderstorm.
Sep 20, 2008 | ViewSonic PJ458D Multimedia Projector
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Computers & Internet Logo
616 people viewed this question
David Payne
David Payne
