Question about Protron PLTV-32 Television
I have a 32 inch proton and would like to moutn it on the wall. The brackets that i find in stores requires the tv to have screw holes spaced along the back of the tv. Mine only has screw holes where the base stand is attached?
  • cln19 Dec 05, 2008
    This sounds like my problem also...no mounting holes except possibly in area where stand is. I am looking for compatible wall mount hardware.
  • 3 Answers
Http://www.acehardware.com/sm-kv-and-reg-shelf-anchor--pi-1294531.html I bought a shelf anchor and a 5/8" x 12" x 36" shelf for around $30 including screws, mounted the shelf on the wall and placed my LCD TV on the shelf. City Mill and Ace Hardware aezd4csells them.
Posted on Feb 05, 2009
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Nov 26, 2010 | Moen Plumbing
I have a 32'' Technika tv and have recently bought a tilting wall bracket do u have to put screws in the back of the tv????
There should be screw holes in the back of your TV.You might want to make sure your bracket screw holes line up with them.
Feb 27, 2010 | Televison & Video
Screw size for wall bracket
Hello. The best thing for you to do is take your bracket to a hardware store and get the largest diameter screw you can that will fit easily into the holes. Regarding length, you should try to screw into the wooden studs behind the sheetrock or plaster wall so you will want 2 and 1/2 or 3 inch screws. Be sure to drill a pilot hole for each screw but only go in half as deep as the screw is long and use a bit that is only half as big around as the screw is.
Jan 14, 2010 | Panasonic Viera TH-50PX80U Plasma TV
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Dec 13, 2008 | Memorex MLTD2622 26 in. LCD TV
Replacement stand
Get/measure/mark spacing of mounting screws.
Punch through paper sheet if necessary.
Measure clearance required to wall.
Find out how much TV weighs.
Search places that sell generic stands,such as E-bay, hardware stores, Hi-Fi retailers, etc.
Match to fit or re-drill holes.
Oct 11, 2017 | Digimate DG4200 42 in. HD-Ready Plasma...
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Protron PLTV-32 Television Logo
179 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
