Question about Jura Capresso C1500 Espresso & Coffee Maker
Can't get any water to come out of hot water or steam dispenser
My machine does not work at all because it says "hot water cycle necessary" and when I push the button, nothing happens. When I switch hot water switch to hot water or steam, nothing happens. There is not water cycling through. Before I changed the water filter, I was able to make coffee, though not steam water. Once I changed the filter, I had to cycle through the hot water cycle before I could make coffee again, and now I'm stuck on the "hot water cycle necessary" and can't do anything with machine.
    Genius:
  • 1,269 Answers
Have you ever tried to reset the machine? You can try to unplug the power cable of the unit for few minutes (10-20) then plug it back in. Hold the power button for about 5 seconds. Check if that clears the error.
Posted on Dec 03, 2008
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
The bleach and softner dispenser does not work. The liquid softner would still be there at the end of the wash - never dispensed. I took out the dispenser and cleaned it, but no change. When I leave the...
Don't know if this is the answer, but my dispensers stayed filled also. repairman said the water wasn't flowing into the machine quickly enough and therefore not tripping the sensor that told the machine when to disburse the softener and/or bleach. He took the cold watersupply line loose, and the mesh was full of sediment. He said it wasn't necessary to replace the mesh. Sure enough, it started working immediately. He did the same for the hot water line..it wasn't clogged.
Aug 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Jura Capresso C1500 Espresso & Coffee Maker Logo
195 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
