Question about Quasar SP-3235 32" TV
Quasar 32" TV VERTICAL HOLD
I have a 32" Quazar TV and all of the sudden the screen started rolling i quess you would call it. I looked all over to find a vertical hold button but i don't see one, there is an action button but when i push it is doesn't give an option for vertical hold. Do you have any idea of what I could do to fix it? Thank you for your time and Expertise?
  • hammw May 12, 2008
    My 27" television has several fine lines at the top of the screen. What is going on with and will it cost alot to repair?
    Scholar:
  • 168 Answers
Well most of the modern tv today doesnt have vertical hold anymore. this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Posted on Feb 02, 2007
SOURCE:
Where is the vertical hold button
This set has no vertical hold control---is picture rolling left right or up down?
Mar 10, 2012 | Hitachi 57F500 57" Rear Projection...
Philips TV 20CT2235/00Z, picture is suddenly rolling vertically. What is wrong?
The vertical hold section of the TV has gone faulty, a component has developed a problem and needs to be repaired. This usually is a job for a serviceman. Ensure you get a firm "Quote" before starting any work.
Mar 02, 2010 | Televison & Video
Vertical rolling during bright scenes w/ high white content
power supply voltage not stable check capactors and look for dry joints.
May 02, 2009 | Samsung TXM3297HF 32" TV
WHAT CAUSES A COMPUTER SCREEN TO KEEP ROLLING
sounds like either the monitor or internal video card is dying, the rolling would be the equivalent of vertical hold button on a old crt tv
Mar 09, 2009 | HP Pavilion dv9000z Notebook
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Vertical Hold Problem when connecting DVD Player
they have different resulutions they can synk
Nov 18, 2007 | JVC AV-32432 32" TV
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Quasar SP-3235 32" TV Logo
1,186 people viewed this question
Top Quasar Televison & Video Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
