Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Generic problem for all Heaters
Electric blanket does not warm
traceywester on Dec 03, 2008
have a sunbeam electric blanket when plugged in one controller flashes. the other controller works fine and one side of the blanket warms. any ideas?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 31, 2008
Not Rated)
Been Around
Rank: Apprentice
Rating: 0%, 0 votes
Call the manufacturer. They will often do repair for free.
Was this helpful?
Yes
No
Solution #2
posted on Dec 03, 2008
Not Rated)
johnatwagga
Rank: Wiz
Rating: 88%, 21 votes
Sorry to have to tell you this, but your blanket is buggered. The cost of repairs will be more than the cost of a new blanket. An unfortunate fact of life in this throw-away age
Was this helpful?
Yes
No
Related Problems
My TH8320U1016 honeywell is O.O.O.The screen is not...
RTH6400 Honeywell - where does the blue wire go. There is...
I have a Rheem Fury-series LP water heater. I'm trying to...
Can you Help with these Heater problems?
1 tank feeding 3 heaters
Solve
1 tank feeding 3 heaters (different houses)ran out out fuel for several months. Just had tank... (More)
looking for climb master termastat
Solve
looking for info on climb master therrmostat
i need a wiring diagram for a...
Solve
i need a wiring diagram for a coleman forced air furnace model number 7670-3751 or 7670-3701
i have a rinnai cosy glow 650 when i...
Solve
i have a rinnai cosy glow 650 when i push the start button it glows up but soon as i let the button... (More)
Hi, i have a Brivis ducted heating...
Solve
Hi, i have a Brivis ducted heating unit (no idea what model)its a roof unit. when we first moved... (More)
Sponsored Links
Describe your Appliance problem:
Select a Category:
Top Heater Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
