Question about Proscan PSVR72 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
My VHS unit played my video tapes great up until I cleaned it this morning with a new wet VHS cleaning cassette. It was probably last cleaned 3 or 4 years ago. Since being cleaned this AM, the drum squeals, the tapes play erratically and have a lot of "video noise". Frequently a tape starts to play, then stops, the drum continues to turn, and the VCR has become noisy on FF and REW. When scanning, the picture is good and without noise. Also, occasionally, it will not FF or rew, but the drum spins (rather noisily) and then the VCR shuts off. It does this with commercial pre recorded tapes also. I've 3 other VCR's which work well with commercially recorded tapes, but have noise, especially at the bottom of the picture (which won't track adjust out). This Proscan is the only one which plays my old tapes well. Just purchased a DVD recorder and am copying many of my VHS tapes to DVD. And I've a couple of hundred to convert to DVD. This Proscan is the only one which plays my old tapes well enough to burn to DVD. Help please.
  • 3 Answers
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Posted on Jun 05, 2007
I recently brought out my vcr and am trying to clean it with Maxell VP-201 VCR pro head cleaner... but it doesn't say how to use it. Do you know where to apply the cleaner on the tape before I put it...
You can usually apply a couple of drops on the tape itself as it will not harm. The tape itself might have a hole located on the cassette itself close to the see through cover. We normal tell people to drop a couple of drops into the tape area
Jul 15, 2011 | Maxell VHS VCR Head Cleaner Wet Type 1...
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
Aug 04, 2008 | Televison & Video
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Sound but only snow for picture
make a deep clean ur video head with a video head cleaner or with a soft cloth with some mild soap.
May 06, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
VCR not functioning
You probably used too much "wet" cleaner on the tape which caused the heads to get fouled. You could try running the wet cleaner through again but use a little less solution than recommended. Failing that you could have the mechanism out of alignment which will require professional help to repair.
Oct 06, 2008 | Audio Players & Recorders
Philips DVP 3200V/37
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Oct 04, 2008 | Philips VR621CAT VHS/S-VHS playback VCR
VCR picture won't work
I have found that just cleaning the head with the tape cleaner (the wet one works best) I have to clean it at least 4 or 5 times in a row sometimes before the picture will come back on. I bet that'll work for you.
Sep 06, 2008 | Orion VR213 VHS VCR
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Televison & Video Logo
477 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
