Question about Sony BRAVIA KDL-40V3000 Television
"Upgrade" of Backlight Panel
For a Sony KLV-32S310A, is a backlight panel "upgrade" possible? If the backlight inverter or backlight "power supply" has failed, should only the backlight "power supply" or backlight inverter be replaced? If the problem is the bad lamp(s), should the bad lamp(s) be replaced only? OR should the whole backlight panel be replaced? OR should the Bravia unit be replaced already?
  • 58 Answers
Just replace what failed.
I replace the surface mount FETs on the inverters.
Posted on Dec 06, 2008
  • thesteve42 Dec 06, 2008
    just replace what failed.
Screen is black, no picture sound is O.K
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name and type of your device, in the search box [at the top right] of the display window; to gather down all the posts related to your device brand. It will make surf easy.
Jul 06, 2015 | Sony Televison & Video
Bravia Model KLV 332S550A. Why sound but no picture?
Sony flat panel having negative image.???
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel.If so, they can't be replaced.In this case; a panel replacement is the only repair.For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS].To such sets, the power supply section circuit too should be troubles hooted.Contact any service technician.The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Feb 26, 2015 | Sony KLV-37S400A 37 inch Multi-System HDTV...
How to fix problem with power supply sony klv 32EX400 ,showing only 3.3v stby
Please specified problem,Check BackLight Inverter Board look for any burnout component,then look power supply,generally Power supply shows only 3.3 or 5v in standby condition,after initialize by control engine you may able to check several power rails.
May 13, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
Electro help
It sounds that the back-light inverter has the fault. If there is any winding short [cannot detected by measuring with an Ohmmeter], this type of fault can occur. The only thing to do is replace the back-light inverter board. The LED blinks indicates a short circuit .
Apr 25, 2013 | Sony Bravia Klv 46X300A 40X300A...
Sony KLV-27HR3 won't come on
Check to see if you are getting a back light by looking through the slots on the back cover. If you are getting a backlight then it is not your power board. If no back light check your connection in another outlet different room if possible or use a long extension. If still no back light then you are likely to need a new power board.
Good Luck Ed Pinero
Feb 03, 2013 | Sony KLV-27HR3 27 in. LCD Television
Sony Bravia KLV-32S310A model - Problem is Power supply okay but no sound & no picture. What can be the problkem?
If the power supply was given a clean bill of health by a reaputable source, then most likely a faulty mainboard
Sep 21, 2011 | Sony Televison & Video
Sound with no picture..backlight working
This failure could be due to a backlight inverter board or the power supply is not providing the 24 volts to it.
The way to fix it is by measuring the voltages from the power supply to the backlight inverter board, if the voltage is present then the backlight inverter board is defective and will need to be replace. If the voltage is lower then 20 volts, then is a power supply failure.
Click here to find the backlight inverter board.
Let me know if you need further assistance. I repair power supplies for all LCD models.
Jul 24, 2009 | ViewSonic N3251w 32 in. LCD HDTV
I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V3000 Television Logo
1,522 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
