Question about Onkyo TX-8210 Receiver
Onkyo receiver playing in mono only
I've just noticed that my 10-year-old Onkyo TX-8210 is receiving local FM stations in mono rather than stereo. My owner's manual says the setting can be changed by pushing the FM Mute/Mode button, but this did not work.
  • James Hannaford Feb 02, 2007
    I think you're probably right, because the local/distance indicator is flickering back and forth. (is that what you meant by "visual meter"? I'll check into it. Thanks a lot.
  • Anonymous Mar 26, 2014
    tune fm receiver sr313
Sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Posted on Feb 02, 2007
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
I have a new Onkyo TX-SR508 receiver. When listening to FM radio the audio cuts out repeatedly for anything from a few seconds to a minute. Power fluctuation is very unlikely to be the problem. Signal...
Does the display show "tuned" or "FM Stereo"? This would normally indicate a good reception. The tuner has a signal level threshold and if the signal gets to week, the receiver mutes to prevent noise in the speakers. Swithing to mono make reception less intolerant. Does the problem also occur, when you switch to mono?
Jul 14, 2010 | Onkyo Audio Players & Recorders
Does The Onkyo TX-8210 take a slow blow or fast blow fuse?
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Oct 02, 2009 | Onkyo TX-8210 Receiver
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Apr 09, 2009 | Onkyo TX-SR701 Receiver
Clicking noise from Onkyo TX-SR606 during television broadcast
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Jan 04, 2009 | Onkyo TX-SR606 Receiver
Can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Onkyo TX-DS484 Receiver
Did you set all your parameters (see manual, page 15)? After that, you can then also change the levels of each speaker (page 16) also.
Feb 12, 2007 | Onkyo TX-DS484 Receiver
534 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
