Toshiba notebook recovery error 10-FC12-0002 - Computers & Internet
  • 1 more comment
  • Anonymous Dec 13, 2008
    It's not the HD, XP installed fine!
  • ama81781 Jan 15, 2009
    I have the same error code - how can i fix it?
  • Jim Strowe May 11, 2010
    Whats the chance your hard drive has gone bad. the fact you're running recovery suggests something blew up.
    Scholar:
  • 118 Answers
Yes, I think this error could be related to the hard drive failure.
try running the recovery discs after the hard drive is replaced.
Posted on Dec 03, 2008
Recovery wizard error codes 10-fc12-048f and 10fc12-0037
Windows files has been corrupted, or the hard drive has issues. This is where a backup recovery disc would be ideal, this would prove hardware issues. At this point have the hard drive tested for errors and bad sectors to see if replacement is required.
Jun 03, 2012 | Toshiba Mini NB505-N508OR EasyGrip Finish...
Getting error code F3 F100 0003 on a Toshiba Satellite L650 running on a Windows 7 Ultimate 32 bit operating system. This code appeared before hard disk drive was replaced and continues to appear after a...
Hi Lea,
If you're getting the F3 F100 0003 error on boot-up, the problem might lie on three things. It's either the a bad HDD, Memory, or the video adapter (which is soldered on the motherboard). Since you already replaced the HDD, the problem might lie on the other two. If you can burn a disc to run diagnostics on your computer, you can use UltimateBootCD or Hiren's Boot CD (more info on the tools here).
I've also seen some errors when you are trying to re-image the HDD using the Recovery Discs and it may have some connection to the error message that you're getting. Here's a list below:
-An error has occurred: ERROR : 10-FC10-1710" -- may be caused by a faulty hard drive.--An error has occurred. ERROR : 10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
-An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
-An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
-An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Hope this helps. Good luck.
Sep 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
Error : 10-FC12-0002 comes up during Toshiba system rocovery what does it mean and how do i fix it?
I download this from the Toshiba support site:
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D / 10-FC11-045D" -- may be caused by a faulty hard drive. *****
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
*for this error 10-FC12-045D u nid to call 1-800-457-7777 toshiba advance technical support they will send it to depot or they will recommend ASP (Authorized Service Partner)
I suppose your recovery disks could be bad. You can get another set from Toshiba. I'm also concerned about the health of the hard drive. Did you need to run recovery because the system crashed, because it may not have been an operating sysem crash but rather a hard drive crash. Have the harddrive or whole laptop checked by a reoutable repair person or check my website: www.micromendllc.com
Mar 03, 2010 | Toshiba Satellite L300D-ST3501 Notebook
System would not boot. recovery disk error
From what I've read on this, it seems to be a hard disk problem. Try to get a diagnostics boot CD (a linux distro). Check the hard drive for errors before using your recovery disks.
Did you change the hard drive by chance? If so, check this link:
http://social.technet.microsoft.com/Forums/en-US/itprovistasetup/thread/41238ab3-154a-4438-b331-3495a827c36a
Oct 07, 2009 | Toshiba Satellite A205-S4617 Notebook
PREINST6.SWM missing; PREINST9.SWM missing; Error:10-FC06-0002
Means pre-installion is missing. Which means yoou either have to Reinstall a fresh copy of your windows or your can reinstall your windows by just repairing the files. Its always good to make a recovery disk after every install. If you haven't tried it already restart your pc press f8 as the scene pops up and go to Last good configuration.
May 30, 2009 | Toshiba Satellite Pro L300 Notebook
System Recovery Media error 10-FA11-045D
This error comes up if the toshiba recovery cannot recognise the file system and partitions. try removing all partitions using the fdisk utility or a windows XP CD and then run the recovery.
Mar 09, 2009 | Computers & Internet
Error code 10-FC06-000D while using recovery cd (backup)
Error code 10 XXXXXXX is related to hardware. It is default code generated by device manager when the operating system failed to determine which specific error code to return after an error occurs.
Error code 10 error pertains mainly to hardware issues and to compatibility issues between hardware and the software.
To troubleshoot the code 10, go to control panel>system> device manager and check if any of the hardware display a yellow “!” or a red “stop”.
1). Update the hardware device driver from either Microsoft or device vendor web site.
If the device is preinstalled on the computer, visit the computer manufacturer’s website.
2). Make sure the device is enabled in the computer BIOS. You need the system documentation, if you don’t know how to do it.
3). Disable any advanced feature of the device.
4). Install the most up to date service pack and any other updates.
Oct 29, 2008 | Toshiba Satellite A205-S4617 Notebook
Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A105 Notebook
Error code 10-fc06-002 in toshiba a200 after running recovery disks
This is a toshiba error when running recovery discs on your machine. There are two reasons that this could occur, one would be corrupted Recovery Discs and the other is bad hardware (Hard Disk Drive).
"An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
Jun 30, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Computers & Internet Logo
1,384 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
