Question about Aprilaire 600 Humidifier
Error Code E3
New humidifier. Installed 11/15/08. Worked great until today.
  • Stephen Evans May 11, 2010
    Does the owners manual have an error code list?
I have the same type of Aprilaire humidifier unit with automatic temperature sensing control. My unit also displayed the 'E3' code. The HVAC technician was on site today and replaced the temperature sensing unit that is located outside the house. The humidifier is functioning normally once again.
Posted on Jan 07, 2009
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
Humidifier not working
Mine is a SUL495 Filter Free unit and worked fine last year and the first couple of days recently, but I'm having the same issue, motor running , no mist, and trying to talk to someone @ in customer service today is a joke, I've cleaned everything but still no luck, I paid $40.00 for this unit in Jan. 2011 and have about two weeks until the warranty runs out, and the other wonderful thing is the nearest service center is about 50 miles away, I may wait until Monady to try to speak to someone, but I probably won't like the answers.
Nov 25, 2012 | Sunbeam SUL496-UM Ultrasonic Humidifier
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Vicks Vaporizer shorting out the house power
could be faulty element or earth leak - as it is new - I strongly advise you to change it at the store you purchased it from.
Jul 21, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Humidifier will not turn on (no fan, no water flow)
http://www.appliancefactoryparts.com/humidifiers/helpcenter/breakdowns/honeywell/honeywell-he360a1027.html
A breakdown diagram of parts etc above.
http://www.appliancefactoryparts.com/content/pdfs/110672-4.pdf
Shows you the HE360A.
To me it sounds like it is wired incorrectly, the solenoid should NOT get too hot at all. The PDF above shows wiring data.
Apr 03, 2010 | Honeywell HE360A1027 Whole House...
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 | Humidifiers
Aprilaire 700a flashers contact dealer light with a code of "E3". turned knob to test/reset and would come on as test, but wont work normally.
i believe e3 is an outdoor sensor problem, most people use manual mode, you should see a blue jumper that is connected to 2 OD terminals at the control, or if u use a sensor there should be a wire run outdoors, if you dont have the manual mode part you have to get it from an aprilaire dealer, cant just jump it out, it is a resistor80027be.jpg
Jul 21, 2009 | Aprilaire 700 Humidifier
Unable to get humidity level above 21% with Aprilaire 700A
Hopefully it was installed properly. It should only allow water to run when the furnaces blower is on. The outdoor probe can only be properly checked with an ohm meter. When you replace the evaporative panel, it is very important to have the dark painted mark on the "top" of the panel when it is installed. They do not give these instructions to a homeowner, only a contractor. So i am betting that your new water panel is installed upside down.
Good luck
Mar 26, 2009 | Aprilaire 700 Humidifier
Aprilaire 600 only operates in test mode...
Call Aprilaire and tell them, this is happining everywhere
Dec 05, 2007 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
1,154 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
