Question about Princeton Digital VL17151 17" Flat Panel LCD Monitor
Princeton VL1715 startup problem
When I boot my PC with the monitors vga cable pluged into the motherboards vga connector, everything goes as expected. BUT when I plug the monitors vga cable into my ATI 9600 Pro's vga connector and attempt to power up, I heard one beep and the monitors led remains orangeish in color. After 20 to 30ish attempts, I'm able to boot successfully. Also when I boot initially with the monitor plugged into the motherboard vga connector , and after sometime in windows, I can turn my pc off, move the vga connector to the ATI's vga connector and boot successfully. I've updated everything! HELP ME PLEASE!!!
    Novelist:
    Champion:
  • 202 Answers
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Posted on Feb 16, 2007
Have old computer ,do not have directdvi-d connection on my computer, can I buy adapter to fit old monitor plug?????
Princeton Digital VL2018W has VGA and DVI input ports, why not use the VGA cable from your old PC to the VGA input of the Princeton Digital VL2018W?
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Aug 01, 2010 | Princeton Digital VL2018W Monitor
Unpluged VGA cable now no display.
This is why it is never a good idea to SCREW in those little crown nuts from your cable to your VGA port. All connections on any PC should remain firmly connected, but unscrewed to prevent damage due to pulling, twisting or removing. All it takes to damage that VGA port is a single push to the wall from the front of your PC. If your VGA pins aren't touching on the board, and if there are no shorts, you can fix your problem by adding a Video card. Otherwise, you will need to de-solder and remove your on-board port completely and try again with the VGA card.
Mar 09, 2010 | ASUS P4S800-MX Motherboard
Out of range no display
Try pressing F8 when starting the PC, but BEFORE Windows starts loading. In the menu, select Safe Mode. Windows now startd with a very low resolution. You can right0click your desktop, select properties, then the Settings tab, and drag the reslution slider all the way to the left in Windows XP, or for Vista and 7, rightclick the desktop, sleect the lowest option, go to screen settings, and drag the slider all the way to the left.
After that, click OK, then restart your PC. Now you can try to increase the resolution step by step, and if it goes wrong start in safe mode and set it back a step. That way you will achieve the highest possible resolutioon (and better image quality)
I hope this helps,
Yannick.
Dec 07, 2009 | Princeton Digital VL173 Monitor
Upgraded to win 7 now princeton monitor goes black how do i fix
try this, but a bit tricky.
start off with the pc off
then turn it on
wait till the bios etc splash screen show past the hit del or f2 to goi to setup then after that press f8 repeatedly until it shows some sort of list
this is the alternate boot up just scroll down to ENABLE VGA MODE
after selecting that it will boot up with your screen..
hope that works
Nov 10, 2009 | Computers & Internet
Where can I buy a VL1715 inverter
Check out LCD Parts for service, parts and DIY info. use this link to their WEB site : -
www.lcdparts.net
Oct 18, 2009 | Princeton Digital Computers & Internet
Need help for my Dell Inspiron 9400 Laptop
Try booting in Safe mode, see if you get video
If you do, reboot in VGA mode, then adjust the refresh rate accordingly
A replacement LCD is about $200 on EBay
Sep 09, 2009 | Computers & Internet
Princeton LCD17 blinks off immediately
Check the VGA cord that connects from the PC to the LCD, try putting VGA cord properly to the LCD and PC, or change the VGA cord. saving mode indicates no signal from the PC. So either the PC is not booting up or VGA cord faulty.
Nov 09, 2008 | Princeton Digital VL1918 Monitor
Dell dimension monitor output broke away from motherboard and now i get no output to monitor to "wake it up", nevermind being able to see anything on it. As soon as i unplug the monitor cable from the pin...
Depending on how much it has broke away, you may be able to resolder it back on, or find someone who can. Other than that it will be a new board, I suspect.
It seems at least a few connections are OK, so probably worth a try, before scrapping it.
Jan 16, 2008 | Dell (W2562) Motherboard
Medion Motherboard
if you cannot reach the BIOS settings screen at power-up, then try another known-good keyboard...it is likely dead.
Jul 05, 2007 | Medion (MT8381) (40004683) Motherboard
Princeton Digital VL17151 17" Flat Panel LCD Monitor Logo
202 people viewed this question
Top Princeton Digital Computers & Internet Experts
Daniel Dollive
Daniel Dollive
Tom Chichester
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
