Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opens after a power surge.
How to correct the problem yourself before replacing parts? I have the same problem, we have had the house closed up with the security turned on, and the garage door opens in a random manner. All of the appliances are off except the refridge. Can anyone please help.
  • 504 Answers
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 28, 2010
Reset after a power outage
A couple possibilities- check for a tripped circuit breaker in your main breaker box, a surge may have tripped these or a fuse internal to the receivers (the inside units) was blown for the same reason
To prevent this kind of damage to all of your wired electronics, consider having a 'whole house' surge protector installed.
Cost: ~$200-$400 dollars and all units with which I am familiar are supplied with insurance against losses for 5-10 years and $10-25.000 in replacement cost.
Sep 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
In the past ten years I have replaced the logic boards nine times. When a storm hits with lighting I loose the board due to surges. I have a G.F.I.out let, surge protector, and I have put a grounding rod...
Chamberlain makes a surge protector that is made specifically for their openers. I would try one of those. The part number is 990LM and should be available from any service company in the yellow pages that advertises Chamberlain or Liftmaster. Unfortunately as you have learned, lightning loves logic boards.
Aug 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 HP auto gargae doors. Lost power during a snow storm. Once power was reconnected only thing that did not work was garage doors. Is there a reset button somwhere....can't see one.
There isn't a reset button. Check the house circuit breaker. You may have had a power surge and that can damage the logic board printed circuit. Check the logic board for missing or burnt traces especially around the small transformer.
Feb 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 3280 completely unresponsive after electrical surge at home? I opened it up and i see nothing wrong. I was expecting maybe board is fried or something .... do not know what to do? I am new to my...
THEY CAN LOSE PROGRAMING IN ELECTRICAL STORMS OR POWER SURGES. UNPLUG THE UNIT TO RESET THE CIRCUIT BOARD.
REPROGRAM ALL REMOTES.
IF YOU STILL GET NO RESPONSE YOU PROBABLY HAVE A FRIED BOARD.
YOU CAN GET TROUBLESHOOTING INFO IN THE OWNERSMANUAL.
IF NOTHING ELSE WORKS CALL A LOCAL GARAGE DOOR REPAIR COMPANY. IF YOU REMOVE THE UNIT AND TAKE IT TO THEM MOST WILL DO FREE DIAGNOSTICS IN HOPE OF SELLING YOU THE REPAIR/PARTS/REPLACEMENT - BE SURE TO ASK IF THERE IS A CHARGE
HOPE THIS HELPS
Jan 04, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door opens w/ Power outages
You will need to get a surge protector on this unit first of all. You will have to replace the logic board and maybe the wall button or sensors depending on how bad the surge was. Any time the power goes out the logic board can be affected by it. Thanks BB
Oct 06, 2009 | General Electric GE 13-438 Overhead Garage...
Unplug the operator for 2 mins.and remove the wires to the wall control. plug the operator back in if the operator starts running  the logic board is most likely fried (bad) and should be replaced.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain access master chain drive garage door opener
First unplug the unit for about 5 min. to reset the circuit board. while you are waiting use an ohm heter or multi tester to see is the limit switch works.
If the switch tests good and resetting doesn't help you probably need a new board.
Be sure to also get a suge protector to help save the system in the future.
Hope this helps
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp fuse?
logic board cooked, replace board or entire unit. use a surge protector. homwowners insurance covers damage.
Sep 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlian 2280 Whisperdrive
Check the light beam safety at the door's bottom, to see if something is getting in the line of sight.
Jul 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
225 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
