Plastic Mountings Let Loose - Hole in back of washer
My Frigidaire Washer GLTF1670AS was purchased on July 14, 2002. IIt lasted a little over 6 years. It developed a squeal so we bought a new belt. When we went to install the new belt, we found the machine was leaking because the plastic mounting bolts had broken and there was a hole in the back of the machine in the approximate size of a fist. This machine was never abused - it was used for the needs of a husband and wife - maybe four loads a week. We understand there have been many problems with the front loading Frigidaire washers. One doesn't expect a machine with such limited use to have to be trashed but it is apparent it can't be fixed. Guess your design engineers goofed on this model.
  • Washing Mach... Master
  • 2,651 Answers
You can fix it buthte cost would outwieghthe cost of new machine,all front loaders not exclusulve frigidaire have simillar issues, if no the tub cracking the rear bearing goes bad
Posted on Dec 03, 2008
Ran one load of laundry in washer, started another and the unit just beeps 3times and I push to reset but lid won't lock or start cycle. I tried moving dials to wake up machine but got no luck
My GE top loader has a little "finger" on the lid , when lid is closed it depress a switch inside a little hole , Now YOU with a wood pencil you turn machine on and press the little switch inside the hole, it may have dropped too low for the "plunger". the washer should start. now tighten the screws for that switch.
Jun 03, 2015 | Frigidaire FFLG1011MW Gas Washer/Dryer...
Hi i have an Frigidaire FAFS4474LW front load washer and it always stuck in the final spin last 6 minutes and it was keep spinning on the last 6 mins and never ended. It takes over 2 hours to finish a...
Thank you for your post, Tom Lau!
I see that you are having a difficult time with your Frigidaire washer, FAFS4474LW, taking long a time to complete a cycle and not rinsing the clothes out enough. This could be a possible problem with your sensor or control panel on your washer. You may want to perform a reset on your washer to help clear out any miscommunication within the washer. In order to perform a reset you would need to flip the household circuit breaker off for roughly ten minutes. If you continue to have issues with your washer after the reset I would recommend seeking assistance from a professional. This will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Feb 17, 2015 | Frigidaire FAFS4474LW Laundry : Front Load...
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
Describe your Frigidaire GLTF2940FE1 Front Load
Run a cycle with just bleach and detergent, no clothes.
Mar 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Motor failure on year old Maytag washer
these washers have a defective motor right from the box, yell louder.
Dec 04, 2009 | Cars & Trucks
2005 Yamaha fuel cap schematic
Gas cap exploded view ( from in the mirror, falling behind me, April 2, 2010 )
I just put mine back together after it grenaded, and I fished out the pieces.
here goes...
1- Chrome cap
2- lock core - ball bearing and short 3 prong black plastic plug in cavity with center pin hole - long black plastic plug in cavity with off center pin hole
3- 4 golden springs to push rubber seal
4- rubber seal w/ 4 leaf clover hole
5- round washer with square hole
6- thin washer to cover o-ring at the end where teeth engage locking claws
7- little black springs between claws and square body of the lock core ( I held them down and compressed to put on the last piece )
finally,... 8- bottom housing with the keyway to align in gas tank
and the famous.... 9- brass screws ( than let go creating this headache ) a little locktite might be a good idea...just a
Oct 24, 2009 | 2005 Yamaha V Star 1100 Silverado
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
the door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Oct 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Have to change cycle manually
Reason? There shouldn't be one. Seems you're extraordinarily unlucky with timers. Mine's 10yo, never broke. The timer is a standalone part, it's not dependent on any other parts for its longevity. So there can't be any other parts in the washer 'killing' it.
Are you handling it gently? Turn it slowly when setting, don't whip it around.
Jul 03, 2008 | Frigidaire GLTF1670A Front Load Washer
Frididair GLTF1670AS Front loader washer problem-water will not run in
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
Nov 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
