Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
I get sound but no picture only with the HDMI cable
I get a great picture and sound with rca cables, and with DVD player, but no picture with HDMI cable. I have replaced the HDMI cable but no luck. I have also reset the TV and cable box and hooked up anoher TV and it works with no problems.
Please HELP !!!
    Genius:
  • 1,239 Answers
HI DID THE HDMI CABLE WIRE{PICTURE ONE) MAY BE FRIED OFF.REPLACE THE HDMI CABLE WIRE AND SEE....
Posted on Dec 03, 2008
    President:
  • 2,712 Answers
There may be some settings required to be modified on the reciever box. Or you can try this. Turn the TV ON with the reciever OFF. When it is fully ON, turn on the reciever and go into its MENU options and try changing the 4:3 Override to some other setting like 'Stretched', etc. This may help..
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
You posted under RCA HDLP61W151 whose rear connectors are only S-Video x 2 • Component x 2 • Composite x 4 • DVI x 1 • FireWire x 1 • Audio (RCA) x 4 • RF x 2 • RJ-45 x 1 while the front are S-Video x 1 • Composite x 1 • Audio (RCA) x 1. Are you using an HDMI to something converter?
Alternately, if your particular model has another HDMI connector especially on the front, pls try there.
Or post back your TVs exact model.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 1,183 Answers
HI,
As you have already connected another TV to the HDMI cable and it works fine, you have answered your question yourself. You need to check the HDMI port on the TV for any problems . I would suggest to get in touch with a local tech., cause this would involve opening up your TV.
Thanks
Proton
Bypassing built-in TV/DVD Player for another DVD player
Connect another DVD player to an unused input port on the back of the tv. If there is a HDMI port available connect it there if the dvd player has HDMI. Then all you have to do is change the input number on the tv. If you get picture but no sound, use RCA audio cables from the player to the tv. Not all HDMI cables pass audio.
Jan 02, 2014 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
I can not get the pic on the tv
If this is a new DVD player that you have connected to your TV,
It can be connected in three different ways using three different cables.
only one type is required
  • one way is using a RCA cable, which is a yellow plug on the DVD and TV
  • another way is a S video cable, which is round and has multiple pins.
  • and the third way is a HDMI cable which is rectangular with multiple pins
Which every one you use, for eg if you use a HDMI cable to connect it up to the TV you will need to select HDMI on your TV via the remote and press TV/AV until you get to HDMI.
Also most DVD players have a menu to set up, which you can select what type of output picture lead you are using, Eg. HDMI or Composite = RCA or S Video.
I have enclosed a picture to determine which lead you are using.
If your TV is HDMI then this will give the best picture quality then S Video then composite RCA.
I hope this helps you
MobileJB
Jul 15, 2011 | Panasonic DMP-BD30K Blu-Ray Player
No sound, picture ok, volume nil
What cable u are using?Like a RCA AV component cable or a HDMI cable?Tries another AV holes in the tv,if use a HDMI cable tries another HDMI hub on the tv.Or replaced with it the new RCA AV component cable or a HDMI cable.
Feb 10, 2011 | Bush DVD2038 DVD Player
When playing a dvd it has picture but no sound.
Check ur inputs and outputs cables connections?Yes,Change the RCA video AV component cable or the HDMI cable,which ever u connected this DVD player in.U might,just have a bad cables problems.
Dec 04, 2010 | Toshiba D-R5 DVD Recorder
Great picture but suddenly no sound over HDMI cable
try replacing hdmi cable. if that doesn't work you have something in the amplifier curcuit bad
May 15, 2010 | Televison & Video
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Dvd installation
Why do you need to connect the rca cables when you get better sound through hdmi?
Feb 20, 2008 | Yamaha RX-V1800
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
109 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
