Question about Kitchen Ranges
I have a whirlpool gold accubake system oven - 3 years old..two days ago the "LOC" and padlock icon appeared. The door opens but all controls for oven are "frozen"...I have misplaced the manual...Can someone help?
  • loriathouse Dec 04, 2008
    The problem with my whirlpool gold accubake system oven went away as mysteriously as it appeared. Thanks to those that offered suggestions.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Htere is a simillar icon inthe number pad itself, look closely and hold it in for 3-5 secs to unlock
Posted on Dec 03, 2008
  • cruiser 1 May 16, 2011
    we tried the solution above, however, there is no number pad on this oven
  • Ron Coons
    Ron Coons May 16, 2011
    although theres no number pad, there should be some sorta print on the console marked "control lock" , perhaps your door "locked" in self clean mode?? are you able to open oven door?? if so if you could post model and manufacture i could help you further with that information
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Whirlpool accubake duo
Long shot...but perhaps the door sensor is not working well....try playing with the latch, and using a penetrate oil on the door latch.
Nov 30, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool Gold Accubake Range
try holding down the start button for 3 seconds
Jul 31, 2009 | Whirlpool GR460 Electric Kitchen Range
The display shows "Loc" and the oven will not work. It earlier displayed E1 F5 and the door would not unlock. I unplugged the stove and plugged it back in, and the door openned. Now it displays "Loc" and...
sounds like the control panel may be locked, look for an icon that looks like a small padlock, push and hold it until the loc goes away, it says 3 seconds but 5-8 is more realistic. I hope this hepls
Apr 12, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Apr 07, 2008 | Amana ARGS7650SS Gas Kitchen Range
Need to unlock the controls of my Whirlpool gas oven
To Lock Or Unlock Cooktop
1. Turn all control knobs to OFF.
2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
onds the clock display will reappear.
3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
3 seconds, and the cooktop icon will disappear from the display.
Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
393 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
