Question about Fisher and Paykel GWL11 Top Load Washer
The tub @ my Fisher&Paykel model #GWL-08-US1 is off balance
The tub is leaning to the right and I don't know if a spring is loose or a mount has brocken off, I looked inside with a flash light and find that a red spring at the front left is the only thing that holds the tub. Is the tub held by rubber mounts or do the springs hold it in place? Does the tub has 4 springs and my machine lost 3 of them? If I need to open the washing machine how do I do it.
  • smithfull Dec 31, 2008
    Water is dripping on the floor during the spin cycle. We tried to find the red latch to attach the spring too but dont see anything. Is the red latch at the top of the drum/tub?
    Thanks.
    President:
  • Fisher and P... Master
  • 2,651 Answers
You can lift the top and get a closer l;ook, by opening lid and looking approx, 4 inches back along side rail, youll see a rubber plug, remove the plugs toreveal the screws hoding down the main top. after emoving screw lift the top back and you see the 4 suspension bars tha hold the machine, either one "popped" or the left front corner should have a sdpring attached form it to the tub( clips on to the red little bracket on side of outer tub). either of thesse swill fixyour problem
Posted on Dec 03, 2008
Small red clip appeared on rim after being off balance. spring attached.
There is a small red clip that holds a stabilizing spring (notice items 7 & 8 in the graphic) which attaches to the top of the tub cover at the front, left side. You might be able to push the tub assembly to the back, right corner to better see this, but it is easiest to reinstall with the top of the machine removed. If the clip is broken or the spring stretched they will need to be replaced. The unit can work without these parts, but is more likely to experience out of balance problems.
Mar 11, 2015 | Fisher & Paykel Paykel White WashSmart Top...
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Model gwl11 load keeps losing its balance and
undo 2 screws at front of machine under lid. they will have plastic covers over them. lift the hob gently and u will see 4 suspension rods holding the tank. before u do this try this. wind the 2 back feet down and the 2 front feet up about 1 inch . this will make the bowl lean towards the front of the machine away from the out of balance lever, which is at the back right. try this see how u go. please reply 4 more help
Apr 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel model GWL 11 Wash tub off center and will not go back into correct position. What is the fix?
wip the top/back off and have a look to see if the two big springs are still holding the drum up, if one has broken or pinged off the drum brops to one side and it also jumps about when its spinning,,,replace the springs
Mar 09, 2010 | Washing Machines
Fisher and paykel out of balance switch fault
Machine should reset when it has regained "balance". It is possible the the OOB switch lever is stuck on the tub ( it is under the top in the right corner and hangs parallel to the tub ). Move tub around and reset load. Sometimes the OOB switch get corroded or breaks and needs to be replaced in order to clear the fault. Call F/P.
Jul 18, 2009 | Fisher Paykel EcoSmart GWL15
Tub goes out of balance every spin cycle
If it doesnt bang and crash around or doesnt seem like there it is out of balance (ie try running with nothing in it) then theres probably and electronic component problem
Jul 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Balance Issues
Depending on the model you have the gwl 10 and 11 have a bal sw located under the console the sw may be engaging causing your problem. ( maybe corroded or shorted ) Or in later and current models they also have bal/shock struts on each side, one of the four maybe worn causing your unit to go out of bal.
Nov 11, 2008 | Fisher and Paykel IWL12 Top Load Washer
My GWL 11 will not drain and spin
lean washer to back from underneath you can acess pump ..pump twist locks to bottom of tub and hoses have finger clamps
Jul 22, 2008 | Fisher and Paykel Washing Machines
SMALL AMOUNT OF WATER UNDER GWL 08 HOW DO I TEST WHATS LEAKING
I can explain how to check and repair this in Live chat. cheers
Apr 12, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GWL11 Top Load Washer Logo
407 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
