Question about Amana Kitchen Ranges
The oven is taking a really long time to heat up
    President:
  • Amana Master
  • 2,651 Answers
Assuming this is a gas range?? if so replace the oven bake ignitor, part number 12400035, cost about 50 bucks comes with all hardware aand instructions, to install. the ignitor is located on the side of hte bake burner under the oven floor
Posted on Dec 03, 2008
My Neff microwave H5470NOG/03 has stopped heating food, any ideas?
It has a internal Dio fuse..You have to take cover off to see it.. Warning...High Voltage...There pretty cheap...
Oct 04, 2017 | Neff Microwave Ovens
My oven takes a very long time to heat up, and never really achieves the set pre heated temp
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | GE Eterna EGR2000EMBB Gas Kitchen Range
My oven seems to take a really long time to preheat -- about 20 minutes to reach 350 Fahrenheit. Is that how long it is supposed to take? Thanks
That would seem to be longer then normal...
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 04, 2011 | KitchenAid Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
It heats up..But it seems to take a really long time to preheat to the right temp
heatman101
Dec 27, 2010 | Ovens
I was wiping out the bottom oven after running self clean. I heard a pop and now every thing takes forever to heat up. It seems like this happened before and there was a quick fix but I can't remember what...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Oven heats, but not enough. Takes a really long
Change the heat element in the oven. You will find it inside the oven towards the back under the pan. The part should cost about $125.00 maybe less. I just did it on my oven.
Jan 04, 2010 | GE JBP66 Electric Kitchen Range
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
Samsung Microwave Oven
Chances are you have a magnetron failing.
It's about time for the keypad to be going too, so unless it's a convection type or you;re really attached to it, it may time to retire it.
If you want to check into parts / pricing, see: http://www.samsungparts.com/search/search.asp
Jun 01, 2008 | Samsung MU3050 Microwave Oven
Kitchen Ranges Logo
131 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
