Question about Microwave Ovens
My Sharp R-430D microwave door latch is loose and causes it to run. If you lift up on the lock side it will quit. When you let go it starts again. Is this an easy fix?
  • Microwave Ovens Master
  • 9,098 Answers
Yes, really.
We have the full service manual, and we have uploaded it our site here to help you.
It contains all the safety, disassembly and door latch alignment info you need.
Posted on Dec 08, 2008
How to unlock sharp stove?
Not super familiar with Sharp Microwave ovens Convection or not,
but most microwave ovens can run into at least two reasons that they won't open and both require you to remove the cover over the whole oven - If the door has a push-button to release the door, you could find inside it has popped free of it's pivots and is not lifting up the latches on the door so you can open it, or is has actually snapped that latch. The other thing I have seen more on Panasonic microwave ovens and again moreso on the newer Inverter ovens, is that the latching assembly inside is attached to too thin a piece of metal and the metal actually bends - now your door and it's latching assembly and switches don't line up properly.
In that case you will still need to remove the cover and do your best to realign the switch assembly with the front of the microwave so that the door can click in and out easily.
May 27, 2014 | Sharp R-1870 Convection/Microwave Oven
Must lift door of microwave to operate microwave.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jun 05, 2009 | Sharp R-9H66 Microwave Oven
Microwave lights up, timer works, not carousel or cooking
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Otherwise, the best place to order Sharp parts is Tritronics.
You can also call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 02, 2008 | Microwave Ovens
Oven makes operating noise when doo is closed without starting
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
The best place to order Sharp parts is Tritronics. You can call them at 866-779-5835.
Nov 21, 2008 | Sharp R-1480 Microwave Oven
My sharp r520lw microwave stopped working.before it stoped working completely it had a problem with the door switch.if i lifted on the door it would work again.now it doesn't work at all.it won't even let...
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switchor mount trouble can be caused by slamming the door or by opening thedoor while it's cooking without hitting the Stop pad first.
There areplastic mounts inside the microwave which hold the door switches andonto which the door latches lock when you close the door.
Sometimes it'sa broken tab on the switch holder, allowing the switch to rotate justout of position. This tab can be hard to see, since it is under thebottom edge of the switch.
One test that sometimes helps is togently lift up (and/or push down) on the door or handle as you try tostart it. If it works or tries to work, then it's a door switch mount ordoor alignment issue.
If you or someone you know decide to lookinto it, we have critical information on safety, disassembly and doorswitches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
If you only need a switch, you can order one from us for $5 postpaid.
Sep 12, 2008 | Sharp Microwave Ovens
Sharp Carousel Over the Range Microwave R-1470 Quite working...has power and control panel works, timer will count down but microwave won't run.
When you hit Start, does the oven lamp come on but not the fan or turntable?
That would be a problem with the secondary (bottom) door interlock switch or its mount.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 18, 2008 | Sharp Microwave Ovens
Sharp R-1460 Over the Range Microwave
This is usually caused by either a bad upper door switch, a loose upper door switch mount, or occasionally a problem on the control panel.
Sometimes it's a lot to just secure the switch with a drop of hot glue instead of replacing the latch head.
Aug 13, 2008 | Sharp R-1870 Convection/Microwave Oven
Fan would go when door opened. Now will count down on timer, but not run.
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Aug 06, 2008 | Sharp Microwave Ovens
I have sharp carousel R-520JK microwave, the clock and other functions work, but it does not microwave/heat...
You can probably find exploded views by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
