Question about HP Office Equipment & Supplies
No power stacker
4500 designjet stacker has no power. Replaced fuse and power supply. Still no power. What else could it be?
  • aconn Dec 03, 2008
    Do you have experience with these stackers.
  • aconn Dec 04, 2008
    Thanks greatly appreciated
    Master:
  • 351 Answers
Dear Aconn,
Its seems that the main board power supply section is faulty, please contact to authorised HP service centre.
Be Happy Always
Regards
Posted on Dec 03, 2008
  • Akshay Choudhary Dec 04, 2008
    yes , i know even i face this problem earlier at one of my client site. please contact to authorised service centre. they will fix it properly.
    Regards
I have a cheverolet Lumina 2006 Car 6 CD power problem but sometimes it work I tried to solve this problem from long time, Anyone can give advice how to power it. (All the fuses checked ok).
built in australia with our commodores
2006 Chevrolet Lumina Royale
cant see any original factory 6 cd stackers for sale in Australia anywhere
better to upgrade to a better after market unit
these CD stacker units do wear out /dry solder /corrosion /diodes
is this the factory cd stacker player that came with that model
..is this unit in the boot
only thing is check all the currents volts to the stacker
make sure the stacker has an individual earth wire
Aug 06, 2016 | Cars & Trucks
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
HP Designet 500 power supply Astec AA20850 dead
Go right to HP dot com and they will have a circuit diagram and parts, service manuals etc.
Jun 02, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
How to hook up fax on a HP 4500 all in one
No fax facility for this models...HP designjet 4500 or deskjet F4500
Jan 04, 2012 | HP Designjet 4500mfp All-In-One InkJet...
Hp Designet 500 plotter power supply fan not rotating
Does it show the HP logo at boot up? Does it show an error code? If it boots but fan does not turn then the power supply must be replaced. If it doesn't boot, then the first step is to replace the power supply.
Jun 06, 2011 | HP DesignJet 500ps InkJet Printer
HP Designjet 4500 Scanner error 55-203,55-205. Appears at calibration at alignment of chambers
55-203
Problem:
No movement in camera position has been detected during vertical camera
alignment.
Possible Solutions:
Check all the cables connected to the Camera.
Run the scanner maintenance program.
May 18, 2009 | HP Designjet 4500 Pass-Through Scanner
Deleted files -how to recover?
www.recuva.com ... it's a freeware program but works well recovering deleted files.
Robert
Please take a moment to rate this solution thanks
Jan 30, 2009 | HP Designjet 4500 Pass-Through Scanner
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
Designjet 110plus nr
the power supply needs to be replaced.
Sep 19, 2008 | HP Designjet 110plus nr InkJet Printer
69 people viewed this question
Seeker5211
Seeker5211
