Question about Microwave Ovens
E-wave microwave model #kot-131uw just quit all of a sudden
Wandering if there is a fuse or something simple that could be wrong.
  • 3 more comments
  • paradisstv Dec 08, 2008
    Been awhile since I posted this so I just went and bought a new one
  • SeriouslySKD Dec 15, 2008
    My microwave just quit too. Home breakers were fine, outlet was fine, all the display just went blank and there was no power to the microwave. Went to start to look for a fuse... then, it came back on. Strange. Not sure what I should do now.
  • toddneck Mar 17, 2009
    Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad, no power at all.. wondering if there is a fuse to replace....thanks
  • Bam_Bam_Dana Nov 23, 2009
    I tried cold booting it. No luck.
    Power supply was good.
    Fuse was good.
    Still looking the net over. I have a strong feeling that it is trash time.
  • William Miller
    William Miller May 11, 2010
    pad on the keypad?
    Is the outlet working?
    Did it quit while it was cooking?
Posted on Mar 17, 2009
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
My chef classic wall oven has suddenly stopped working. It was working well, then suddenly nothing. Is there a fuse or something simple that can be fixed?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 02, 2011 | Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
E Wave microwave stop heating
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Dec 27, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
Microwave Ovens Logo
1,062 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
