Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
How do you access the blower wheel on a maytag stackable dryer. I have the LSG7800AAW, the housing is on the lower left but after removing the four hex screws the housing does not come off. Can anyone explain how to access the blower wheel.
  • pop302 Dec 03, 2008
    When you take the front panel off there is a front housing on the ower left that seems to be connected to the lint trap. I can't figure out how to get that part off.
  • psmsmallengi Dec 04, 2008
    I have to replace the drumm Belt and Drum roller/Idler pulley on my LSG7800AAW too. Email me at psmsmallengines@hotmail.com and I will tell you how I fare doing this job.
    President:
  • Maytag Master
  • 2,651 Answers
After removing te front panel you can see the blowe rwheel inside hte housing, probably 6 1/4 hex screws holding sheetmetal face on housing as well as to 5/6 hex screws holding motor down
Posted on Dec 03, 2008
  • Ron Coons
    Ron Coons Dec 03, 2008
    that part actuall comes off with the entire fomt panel( facade and door assmebly), not clear in pic, and honestly without looking acnt remember how, but id imagine there are a few screws on either side of bottom and perhaps a few across the top
Replacing pulley on Blower Housing
If there is no access panel on lower right side behind machine, you will have to lift the top of the machine from the front and remove the front panel to access the inside of the machine. While there it would be a good idea to check out the drum rollers if present and drum glides for wear. Also make sure that the blower wheel is not loose on the motor shaft. All of these will cause noise issues and are common.
Jul 31, 2013 | Maytag Bravos XL High-Efficiency Electric...
Maytag Legacy series dryer making loud noise. Sounds like something flapping.
A common problem on these dryers is the blower wheel itself will wobble out and make noises. Pop the top with a putty knife then remove the front panel. Check the blower housing for looseness.or something in it. I worked on a monkey wards dryer with a bad blower wheel and made crappy movie on my phone:
Sep 04, 2012 | Maytag Dryers
How to replace heat blower
NOTE: The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the passenger side cowl trim panel. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair\Cowl Trim
  3. Pull back the carpet to access the front upper screw that secures the air inlet housing.
  4. Remove the recirculation door actuator.
  5. Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
  6. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
118348823 Lower Air Inlet Housing
  1. Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
  2. Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
118348824 Blower Motor Wire Lead Grommet
  1. Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  2. Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  3. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  4. Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
118348825 Blower Motor Mounting Tabs
  1. Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
INSTALLATION
Nov 28, 2011 | Chrysler Sebring Cars & Trucks
I have a maytag heavy duty gas dryer model number LDG412 i need to know how to clean the vent all the way to the duct, the dryer is getting hot but it is taking a long time to dry clothes now, inside where...
while cleaning the venting is never a bad idea and i recommend its done yearly,a common problem with older (the ldg 412 is from the mid 1980's) Maytag dryers isa stripped drive hub on the blower wheel and absolutly no air is being circulated throughout the dryer. A lot of times when starting the dryer and when it stops a rumbling noise will be made if the blower wheel is the problem. To check it if is the blower wheel you can remove the front panel by removing the screws that are a slight angle at the bottom of the front panel,tilt it out toward you at about a 45degree angle,then off. At that point remove the four 5/16" hexhead screws holding on the front drum support,lift it up slighly then off. The blower wheel will be in the lower left corner and you could spin it by your hand if it spins around the motor shaft it slips onto and does not move the drum while turning the blower wheel,it is stripped and needs to be replaced.To replace it remove the 1/4" hex head screws that hold the front plate to the plastic blower housing(7 screws) and the 5/16" hex head in the tab also in the plate in the front of blower housing the plate where come off. To replace blower wheel remove the greenish/black clamp from the center hub and the thin metal ring that fits ina groove on the motor shaft, a special c/e clip ring pliers are needs to remove the ring. A inexpensive pair could be picked up at most places that sell tools(ace hardware/lowes/home depot/sears) The part number for the blower wheel is 303836 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
I hope this will help you to repair your dryer,
Gene
Aug 07, 2011 | Dryers
Made a odd sound like a spoon in a garbage disposal then would not turn on.
Hi, thanks for using FixYa.com! I suspect there is something caught down in the blower wheel. To access, remove front panel by inserting a putty knife between the lower panel and upper panel about 2" in from each side. Depress clips and pull top of lower panel down, pull panel off and set aside. Remove lint filter and then remove the two 1/4" screws from each side of the metal filter housing. Remove housing to access blower wheel and remove any foreign objects, likely to be an underwire from a bra...most common!
Sep 16, 2010 | Kenmore 63942 Dryer
Where is the blower motor... i know that is the problem, but where and how do I change it. i already have the part
Blower Motor Removal & Installation Front To Remove:
NOTE: The blower motor is positioned on the passenger side of the vehicle beneath the instrument panel, and can be removed from the vehicle without removing the HVAC housing.
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Passenger side cowl trim panel
    • Carpet to access the front upper screw that secures the air inlet housing
    • Recirculation door actuator
    • Recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside
    • Blower motor wire lead connector from the blower motor resistor or power module, depending on application. Lower Air Inlet Housing chr_pacific_lwr_inlt_hsng.gif
    • One screw (from the top) that secures the lower air inlet housing to the upper air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing Blower Motor Wire Lead Grommet chr_pacific_blwr_wrg_grmmt.gif
  3. Feed the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  4. Push the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  5. Place the recirculation-air door as needed to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  6. Lightly bend the recirculation air door far enough down to remove the blower motor and wheel from the HVAC housing. Blower Motor Mounting Tabs blwr_mnting_tabs.gif
  7. Remove the blower motor and wheel from the HVAC housing. Make a note of the location of the blower motor mounting tabs.
To Install:
  1. Install or connect the following:
    • Blower motor and wheel to the lower half of the HVAC housing and line up the blower motor mounting tabs to the correct location on the HVAC housing
    • Blower motor and wheel into the HVAC housing by lightly bending the recirculation-air door far enough down
    • Three screws that secure the blower motor to the HVAC housing by positioning the recirculation-air door as needed
      1. Torque to: 17 inch lbs. (2 Nm)
    • Blower motor wire lead through the opening in the lower air inlet housing and seat the rubber grommet into the lower air inlet housing
    • Recirculation-air door pivot into the lower air inlet housing
    • Four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and the lower HVAC housing
    • Blower motor wire lead connector to the blower motor resistor or power module, depending on application
    • Recirculation door actuator wire lead into the routing clip located on the lower air inlet housing
    • Carpet
  2. Perform the heater-A/C control calibration procedure.
Rear To Remove:
NOTE: The rear blower motor and blower wheels are repaired only as a balanced unit. The entire blower motor and wheel assembly must be replaced if either component is fault or damaged.
    • Front center floor console cover
    • Negative battery cable Rear Blower Motor Housing chr_pacific_rear_blwr_hsng.gif
    • Body wire harness connectors from the rear blower motor power module and the rear mode door actuator
    • Body wire harness bracket from the console support bracket
    • Eight screws and the two console support brackets from the floor console base and duct assembly
    • Four screws that secure the rear blower motor housing to the floor console base and duct assembly
    • Rear blower motor housing and place it on a bench
    • Rear blower motor wire harness connector from the power module
    • Eleven retaining clips and three screws that secure the housing together
    • Two halves of the housing
    • Blower motor wire harness and grommet from the housing and remove the blower motor
To Install:
    • Rear blower motor into the housing and install the blower motor wire harness and grommet
    • Two halves of the rear blower motor housing and install the eleven retaining clips and three screws
    • Rear blower motor wire harness connector to the rear blower motor power module
    • Rear blower motor housing into the floor console
      2. Two console support brackets onto the floor console base
      3. Eight screws that secure the support brackets to the floor console base
      4. Body wire harness bracket onto the console rear support bracket
      5. Body wire harness connectors to the rear blower motor power module and the rear mode door actuator
      6. Negative battery cable
      7. Front center floor console
  2. Calibrate the A/C-heater control.
Aug 13, 2010 | 2004 Chrysler Pacifica
I need to replace a heater blower motor on a 2004 chrysler pacifica and picture schematics etc;
INSTALLATION
  1. Position the blower motor and wheel to the lower half of the HVAC housing. Align the blower motor mounting tabs to the correct location on the HVAC housing.
  2. Gently flex the recirculation-air door far down enough to install the blower motor and
Dec 02, 2009 | 2004 Chrysler Pacifica
How do you access the belt tension pulley wheel on a Kenmore Elite HE4 dryer?
First, unplug the dryer. Live voltages are still present inside the unit even with the dryer turned off. Then, follow these steps:
1. Remove the lower panel under the door. The screws are located under the bottom edge. With the screws removed, the panel will drop down, then slide off.
2. Open the door and remove the lint screen. Close the door. (The reason for this is because you cannot remove the blower fan housing with the lint screen in place.)
3. Remove the blower fan housing. There should be three to four screws with a retaining clip on the bottom holding it in place. Loosen all the screws. With the screws removed, pull the housing towards you from the top first, while releasing the retaining clip. The whole unit should come out. NOTE: Some blower fan housings have a ground wire attached. Make sure you disconnect the wire if this is the case.
4. With the blower fan housing removed, you should have full access to the belt tension pulley on the right hand side next to the heating element.
Is there a reason why you need access to the belt tension pulley? If you need further assistance, please let me know. I hope this helps you.
Jun 21, 2009 | Dryers
Need to know age of stackable
I purchased mine brand new in 1993.
May 27, 2009 | Maytag LSE7806A Top Load Stacked...
Blower wheel loose on shaft of motor on maytag dryer
GO TO www.repairclinic.com and enter the model number look for your blower wheel item 1245880 it looks as if there is a flat side on it. this may help ya Good luck
Apr 09, 2009 | Dryers
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
