P4sd-vx mb this board has like 2 places for usb and about 16 pins i need to no where they go so my box can use the front 2 usb ports. Any help would be great thank you
    Genius:
  • 1,061 Answers
Http://motherboards.mbarron.net/forum/viewtopic.php?p=1888 Board specs and your info are here.RICHARDM69
Posted on Dec 09, 2008
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
Hi anyone know what graphics card i can use in a hp P4SD-LA (Stingray
Hi patto1974, this is a good Model Graphics Card, for the ASUS Motherboard that you have. ASUS is one of the leading Manufacturers in "Gaming Computers; so you want to have a Graphics Card to compliment the system.
This is the (Model):
Radeon HD 4670
IceQ
Video Card
1GB GDDR3
AGP, DVI, VGA,HDMI
Item#: H231-4678 '
Model#: H467QS1GHA."
You can find this "Model at Tiger Direct, along with other models.
Use AGP x8 as the reference search!
Click here: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=318
Hope you are satified, paul7of9
Jan 09, 2012 | ATI Computers & Internet
I want to connect My front USB to the Gigabyte MB ga-945p-s3 i dont know how to do it right if there is a video to show me how to do it, that would be great your help is needed thanks
There are two connectors on the motherboard marked F_USB1 and F_USB2 for the front panel USB ports. This is the page from the manual (you can download a copy here) for your board:
The pinout of each USB connector is the same, so it does not matter which one you use. Each connector supports two USB ports. The pin assignments are a standard, and the cable from the front panel USB connectors in your computer case may already have a plug on the end which will fit. Note the missing pin (pin 9); the plug is keyed so it will only fit one way so you can't put it on backwards.
If the front USB cable in your computer case doesn't have a 10-pin plug on the end, it will have a separate single-pin connector on each wire, and they will be marked with their function. Make sure you match each wire to the correct pin on the board, following the chart shown above.
You should have your front USB working very quickly. Thanks for using Fixya!
Dec 03, 2010 | Computers & Internet
P4SD-BO-R bios updates / manual
You will NOT get around the password. None of the tricks work. BUT, there is a very easy solution for bypassing the Password on this %$$##@@!! MB. There is a small green jumper near the CMOS battery. It covers 2 pins. Remove that jumper. You're Bios is now no longer password protected and you can do that micro update stuff. OK, so I solved your problem. Now someone else's turn to solve mine. I cannot get the audio to work on this delightful MB. Downloaded the new drivers, etc. Anyone out there solved this one? Running XP.
Thanks,
Gregg
Jul 09, 2009 | Computers & Internet
ASUSP4SD-VX Can not figure out how to configure plug for front USB panel to motherboard, when using this mothervoard in a generic case.
your motherboard only supports USB v1.1, make sure those are they type of connectors on your case, and if so, open this document and go to page 2-16 for diagram: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4sdr-vm/e1104_p4sdr-vm.pdf
if the case only has USB v2.0 plugs, you cannot connect them.
Jun 28, 2009 | Computers & Internet
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Front usb ports
Follow the interior cabling of the front usb port to the Mb where its pluged in. Checking the cable as you go.
You'll need your manual for this. The pins are not in the correct order for "your" board.
Dec 22, 2007 | ASUS M2N-MX Motherboard
Open Questions:
USA@#1-877-778-89-69@#Avira Customer Support Telephone Number? Call USA1-877-778-89-69 Avira tech support is offer the power of any time, anyplace with the assistance of Avira Antivirus support phone number . Any body will easy accessibility the Avira Antivirus Support Phone Number. Avira Antivirus Support number provides technical help and support services in respect to the software system .Our expert Solved all type of issues i.e Netwok conflicts,Firewall configuration and window issues etc. For more detail call:1-877-778-89-69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.Avira Antivirus Support Phone Number, Avira Antivirus Customer Service Phone Number, Avira Antivirus Tech Support Phone Number, Avira Antivirus support Helpline Number, Avira Customer support Telephone Number.Avira Helpdesk number,Avira Tech support Telephone number.
May 24, 2017 | Avira Computers & Internet
Computers & Internet Logo
840 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
