Question about Hitachi 43FDX01B TV
Picture and sound drop out
Both the picture and sound "black out" for a second or two at a time. This occurs usually when there are bright flashes on the screen. So a movie with explosions or special effects or cameras flashing can cause it to happen quite often. Watch something low key like the news or the program guide and it never happens. The TV has a great picture and is worth repairing, though at 6-7 years old is not worth dropping $500 or so on. So I'm wondering if anyone has a clue what I may be getting into here. It also happens more often in HD (you can adjust the signal from the satellite box). Thanks!
  • whosknockin Dec 03, 2008
    It was suggested that I was losing signal, that it was the satellite or wires, not the TV. This has been going on for some time, through two different different satellite boxes and different wiring configurations. I don't have HDMI, so have hooked up as both component and S-video, currently component.
    President:
  • 2,110 Answers
It seems some capacitor proble in ur circuit board ,so take ur unit to nearest service center...
Posted on Dec 03, 2008
    Genius:
  • 1,239 Answers
HI Replace the lamp. This is common with sony projection lamps when they go bad they start this turning off and back on. Replace the lamp should fix all of you worries.
  • ABHISHEK.C
    ABHISHEK.C Dec 03, 2008
     Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
    total cost of repair $.00
    time required to fix, less than 15 minutes.
  • 102 Answers
This sounds like you are losing signal because you are losing sound and picture. It has something to do with your satellite not the TV
  • Kenneth Crowther
    Kenneth Crowther Dec 04, 2008
    if you are losing audio and video at the same time it has to be the board is going out or a loss of signal. It can take a while to go all the way out. It is basically trying to turn it's self off when it flashes like that. Bright pictures are overloading it more. Soon it will happen more frequent. Take it in with a print out of these solutions.
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Bush LCD32TV005HD picture flashing on and off 4 to 5 times per second. Sound is fine. Feint clicking sound as the picture flashes on and off
These flashes, otherwise known as blinks, are sign of fault inside the TV. By the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of flashes at one time switch ON carefully for at least two times, and make sure about it. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 19, 2013 | Televison & Video
RCA L32HD32D no picture
Most likely you have a bad back lamp. Most times when this occurs, the screen will come on for a second or two then go off. Replacing a back lamp isn't a job for do it your selfers. It will involve completely disassembly of the LCD panel.
Jan 12, 2013 | RCA L32HD32D 32 in. LCD HDTV
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110.
Sep 07, 2008 | Toshiba 57H81 57" Rear Projection...
Black screen
when problems occures with monitor is always with picture tube but some time less brightness is also reason for black screen
check brightness of your system i think it should be on maximum level and brightness is perfact so i said problem with picture tube. may be picture tube is gone...
Mar 28, 2008 | Acer Aspire 5050-3242 Notebook
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Oct 29, 2007 | Samsung Digimax S500 Digital Camera
Hitachi 43FDX01B TV Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
