Question about Brother MFC 210C All-In-One InkJet Printer
Brothers MFC 5440CN says near empty yellow & magenta with new ink
Brothers MFC 5440CN has error message "near empty yellow" then "near empty Magenta", immediately after I replaced the ink cartridges. It said 'near empty yellow" before the replacement. Color printing all comes out as green and orange. I reinstalled the cartridges [Brothers brand], cleaned, aligned, still acted the same. I uninstalled and reinstalled the program, still the same. Then it quit printing at all. I used 'Repair" and restarted the printer. Now it will print from 'WORD' or other applications but the color still prints in yellow and green stripes and the same error messages are on the printer screen.
I hope you can help me with this.
Thanks in advance.
5 Suggested Answers
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
  • 23 Answers
SOURCE: one color is not printing properly ( magenta )
use a qtip and clean teh wipeoff area where the cartridge goes...
that and clean all around where the stripe may develop...
Posted on Jul 29, 2009
  • 254 Answers
SOURCE: Brother MFC-5440CN wont feed 2 colors of ink, Yellow and Magenta and also says
This may be due to the fact that you have not removed correctly the small label that seals the air input to the cartridge. Normally on brother cartridges it's on the back or on the top of the colored label. Please check that. If no air is allowed in then your ink will not be provided thus generating your problem.
Posted on Oct 27, 2011
  • 254 Answers
SOURCE: Brother Mfc-5440CN Yellow and Magenta will not
Have you executed a forced head cleaning?
Are you sure that the cartridges are correctly placed and the output punched ?
Posted on Nov 03, 2011
Oct 27, 2011 | Brother MultiFunction Center MFC-440CN...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
On bro copier mfc 3240c printer will not copy with only black ink full and magenta empty and others near empty. will copier not wk if all are not replaced when empty or near empty???
check with brothers tech support to see if you can set the machine to use black toner only... if not then you have to replenish all the empty or near empty toner cartridges...
Dec 18, 2009 | Office Equipment & Supplies
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Mfc 3249c
Ensure that you are replacing the cartridge with a Brother LC41M ("M" denotes magenta) cartridge instead of replacing it with a "knockoff" (third-party equivalent) or refilling the cartridge. Some third-party inks -- found in many knockoffs and ink refill kits -- do not work well with their intended cartridges and/or print heads. I discovered this the hard way, and then verified it with representatives of HP, Canon and EPSON.
If you have tried two or more actual LC41M cartridges and still receive the Near Empty error message, your unit might need service. Contact Brother Customer Service for further troubleshooting -- see page i of the Users Manual. (Opening the Users Manual with this link requires a PDF viewer such as Acrobat Reader or Foxit Reader.)
Feb 29, 2008 | Brother MFC-3240C All-In-One InkJet...
Printer will not print black.
Try removing the magenta completely and shut the lid then open again then insert the new magenta and see if the ink device level on the PC shows full. Sounds like the system needs resetting. Alternatively change the magenta and power on and off the printer and see if this resets it.
Aug 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
