Question about Sony VAIO GRX560 PC Notebook
Power lite is on cd spins up, no hd lite, no screen come on
Is the bios working is the hd bad?
  • EvilJoe May 11, 2010
    A dead HD rarely will kill the video signal too, you don't need a HD for the bios to work and at least get to the command prompt. A dead processor on the other hand won't let the video signal come through, blank screen and no POST beeps are a big clue. Check the memory in another unit if possible, that's the easiest place to start.
  • zabrina liang May 11, 2010
    Are you getting anything on screen?
    Something funky could be goin on with the ligths OR
    Your hard drive crashed.  If you cannot bring up the bios, you will need to have it serviced. They may be able to salvage the data and files, but all depends on the state of the hard drive.
    Also, What were you working on/doing prior to this episode?
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
1100 ferrari acer power but no screen?
Assuming no BIOS is displayed
  • Memory could be bad
  • Motherboard could be bad
  • Backlight could be bad
  • Inverter could be bad
  • Screen could be bad
Pull the memory modules out and boot the computer if it makes it to BIOS and then beeps at you one or more of the memory modules are bad, replace one at a time if you have more and test until it breaks again then you know which to replace.
To Test the inverter and backlight hook up an external monitor and boot the computer. If it displays correctly on the monitor then you've narrowed it down to a bad screen, inverter or backlight. Backlights don't usually go out.
Remove the monitor and boot the computer. Shine a flashlight on the screen and look for a very faint image of what should be displayed. If you see one I'd start by replacing the inverter. If you don't see one the screen is bad.
If none of this worked then replace the motherboard.
Dec 15, 2012 | Acer Ferrari 1100 Notebook
My Acer ASpire M1641 desktop isn't booting, not even to the BIOS screen. It was running & I was on the internet when it flashed a blue screen too fast to read, then stopped dead. I get no display on...
Even though the fan on the graphics card spins, it may still be the power supply. Try another power supply before anything else, its your cheapest option as well as a new motherboard will cost more
if this helped you please vote
Feb 25, 2011 | Acer Computers & Internet
After power on my eMachines C6537, there is no beep sound and nothing shown on screen. The CPU fan and fan in the box are working. The HD drive spin sounds normal. No problem to open doors of DVD and CD...
Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
Jun 27, 2017 | eMachines C6537 PC Desktop
Will not boot give error code one long beep tone 2 short no screen no HD or display Tone will not happen if Memory is out . HD is not powering up not backlight to screen no fan sound this is a Toshiba...
Without knowing which bios chip is in the machine this will be quite difficult. One long and 2 short beeps, with some bios chips, means faulty graphics controller chip.
Jun 06, 2009 | Computers & Internet
Dell inspiron 1000 power lite comes on then goes off cd works, num lock lite on, screen not on and then power light goes off other lights on and cd works, hd light not on.
Motherboard failure. You can find replacement motheboards on Ebay but this is such a low end system it isn't really worth repairing
Jan 20, 2009 | Dell Inspiron 1000 Notebook
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
Mar 19, 2008 | Toshiba Tecra 8100 Notebook
Laptop won't BOOT
This is VIkram Kumar Thumu from India- Hyderabad. I have seen your message at this web site... and I would like to provide my solution on the issue.
Well, the message " 1-07 test failed " by HDD test in BIOS confirms that Hard Disk Drive of your Laptop is gone bad .
Hence to resolve the issue, need to replace a new Hard Disk Drive for your notebook.
I am sure that this will resolve the issue.
If you have any queries or issues you can mail at thumuvikram@rediffmail.com. I'll be glad to answer ...
Thank you.
Bye.
Vikram Kumar Thumu
Feb 19, 2008 | HP Pavilion ze2000 Notebook
Power Up Problem
If its unplugged and its doing this with a charged battery, then the battery may be bad and its max charge is so small that it wont start but says its full.
Try removing the battery and plugging it in and starting it, if it works, Bad Battery.
Itry removing the CD drive, some older Dells would do the same thing when the drive or bagttery would go bad. If so, then Bad Drive or battery.
Try taking out the Hard drive and then starting it with no Hard drive and see if you get a bios screen, if so, go into the bios and reset everything to defaults and try starting it again with the HDD put back in.
If its really old, past 3 years, the bios battery may have god out and needs to be replaced, some laptops have a watch battery soldered in or a rechargabl battery that connectd to the board, if so, its up to your ingenuity to replace it with a new one however you can. although i would try this if your not mechanically inclined, taking apart, most laptops is difficult unless its your job and you know your stuff.
Hope this helps a little.
Feb 15, 2008 | Toshiba Satellite M45-S265 Notebook
Problem with my dell dimension 4600
Does the hdd lite come on? cd lite come on? The blinking lite on the power is an indication the bios or power supply is having trouble. strip the unit of all devices except hd, kb and use the vga built in video. Remove the ram also. restart and see what happens.
Dec 08, 2007 | Dell Dimension 4600 PC Desktop
Sony VAIO GRX560 PC Notebook Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
