Question about HP LaserJet 3330 All-In-One Printer
Hi My LaserJet 3330mfp printing 3 shadow line on Letter size paper 2inch between the lines
  • Larry Linch May 11, 2010
    Have you tried another toner cartridge?
    Larry
    Novelist:
  • 125 Answers
You may be having a problem with the cleaning blade that is in you toner cartridge. You will have to replace the toner cartridge.
Posted on Jan 08, 2009
Tip
Lexmark laser paper jams and wrong size paper reporting
the quickest way to find out if your paper jams are due to wrong size paper reporting is to print the network status page.
This page is outline with a line that runs 1/2inch from the edge all the way around the outer edge.
if the box of this page prints smaller than the letter size paper the paper reporting is smaller than 8 1/2 x 11 and if the line at the bottom of the page is missing its reporting a size larger than 8 1/2 x 11 either of these occurances willl be the cause of your paper jams
on Jun 07, 2010 | Office Equipment & Supplies
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
I have an hp2430, it is pringinting shadows along the left edge of the papers and a line along the right side. I have printed a cleaning page 3 times and replaced the cartridge, running the cleaning page...
the line could be caused by a scratched DRUM unit or a contaminated trasfer roller... And the shadow is probably a broken MICA ROLLER in the FUSER,
To get rid of the line (if the drum is OK) you need a mantenance KIT for that model, (pickup roller, transfer roller, separating pads etc...), for the shadow you need a new FUSER
Cheers!
Mar 22, 2011 | HP LaserJet 2420 Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
When trying to print Avery Labels L7160 the top few labels print within each label 'frame' BUT towards the end of the page the labels are printed further up and therefore are out of the label 'frames' ALSO...
For Word 2007/Word 2010
1- Click on the Office button
2- Select Print then Print again.
3- In the Zoom section make sure 'Scale to paper size' is set to 'A4'
4- Click on the Properties button.
5- Click on the Paper / Quality tab, then click on Advanced.
6- In the Paper/ Output section it has Paper size. To the right you have a drop down menu . Make sure A4 is selected and not letter, then click on OK.
3- There may also be other options in your printing preferences such as 'Print Area', 'Scale to Fit Page Size' or 'Page Margins. These will all need to be set correctly for your design to print 100% e.g. Print Area set to Maximum, Scale to fit Page Size disabled and Page Margins set to Minimized.
Some printers ( for example Epson printers ) have a 'Reduce /Enlarge' facility that defaults to 94% or 97% (instead of 100%). To set this to 100% click the 'Layout' tab and in the 'Reduce/Enlarge' section select 'Custom' you should then be able to change the scaling to 100%.
Mar 12, 2010 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
HP LaserJet P2015dn
sounds like you're dealing with Postscript issues here. Does your HP have postscript drivers installed.
you might want to check on the current Mac drivers through this link
Mar 08, 2008 | HP LaserJet P2015dn Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
HP LaserJet 3330 All-In-One Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
