Question about Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan
My Bryant furnace never shuts off. Do you all know about furnaces?
  • 744 Answers
Firts, make sure the fan switch on the thermostat inside the house is set to "Auto", not "On"
Next, turn the furnace off at the thermostat, wait about two minutes and turn it back on. Sometimes it's just a glitch.
If that doesn't work, you may have a malfunctioning or stuck thermostatic limit fan control. This control starts the fan at about 140 degrees in heating mode and then turns the fan back off at about 120 -130 degrees. Some units use "snap discs" instead of a thermostatic control to control the limits. If they go bad they must be replaced.
If you are not comfortable doing this kind of work or don't have the tools, call a competent HVAC repair shop.
Posted on Mar 28, 2009
    Novelist:
  • 189 Answers
I need more info. but it sounds like a bad thermostat to me
  • Lou Barta Mar 28, 2009
    check your thermostat
On a Bryant furnace 373lav what is error code 41 furnace tries to light imonitor lights up but the won't light
Code 41= blower out of valid speed range. you will more than likely need a new motor module. they are not cheap 300$ to 400$. If you call a carrier or bryant tech out they should have a test module they carry on their truck that lets you know if its the furnace circuit board or motor module.
Jan 02, 2015 | Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Furnace error code 42
have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 12, 2014 | Heating & Cooling
Bryant 345mav furnace shuts down early after one minute
Try to jump pressure switch as soon as the inducer come on and see if it stay longer. if it does you might have problem with draft or pressure switch itself defected.
Nov 28, 2013 | Heating & Cooling
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Wiring to bryant furnace/ac
your t-stat maybe now not talking to the furnace remove it temporarily to check
Apr 09, 2009 | Honeywell Electrical Supplies
Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan Logo
148 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
