Question about Dryers
My dughter dropped an empty gum wrapper into the lint trap slot on an older whirlpool...anyway to get it out without taken aprt the whole darn thing?
  • Dryers Master
  • 2,651 Answers
The lint filter up top??? if so can oyou hear hte gum wrapper making noises???? if not i wouldnt worry about it, that bent is a direct vent thoughthe blower fan housing and strait outside! id worry if a sock or bra, something of that nature, not a gum wrapper youll be fine
Posted on Dec 03, 2008
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
Well, well.
Am I to understand the timer dial is going really fast as you watch it?
I didn't know that was possible, but maybe the wiring has been compromised (shorted out) somehow. If so, you would need to take it all back apart and look for a wire that is pinched or incorrectly hooked up. Some Whirlpool dryers have numbers on the back of the timer that are supposed to match numbers that are actually printed on the wires themselves.
As far as the lint trap, perhaps one of the "pipes" inside the dryer is unhooked or loose causing the hot air to miss the screen.
Be blessed.
some were he has blocked the out let for lint trap the reason its stopping is its over heating don't use untill sorted it will cause a fire if left
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Is there a lint trap or lint filter on this washer? It is a kenmore washer model# 11022622100. I seem to remember my old washer having one inside the lip of the tub but I can not find one anywhere.
On most 110 mods there was what they called a lint trap at the bottom of the wash basket.You can;t see it without taking the basket out (ya I know dum) you will need special tool to remove basket.that filter has now been replaced by whirlpool with 4 little plugs and the so called filter is removed.You can clean the old one and unit will be fine..for that job I would say to get a pro as it takes me about 2 mins to open and will save you as a home owner a whole lot of headaches..Hope I helped and Thanks for voting
Just a note that whirlpool made that machine.
Mar 17, 2011 | Washing Machines
Dryer spins and gets hot but clothes do not dry
Sound like the air is trapped in the dryer. Is your lint trap empty? Is the dryer properly exhausted and the ductwork clear of lint or obstruction?
Oct 08, 2009 | Whirlpool Inglis IP8200 Dryer
Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Jul 13, 2009 | Whirlpool Dryers
Candy wrappers & lint stuck inside the drum
un screw from in side thanx for useing fixya rate me
Mar 31, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
May 17, 2008 | Whirlpool GEQ9800P Electric Dryer
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryers Logo
93 people viewed this question
Top Dryers Experts
