Question about Whirlpool GT1195SH Microwave Oven
FLASHES INSIDE OF MIRCOWARE AFTER IT IS STARTED AND MAKE NOISE
AFTER YOU START THE MIRCOWAVE, THE UNIT WILL START TO FLASH INSIDE AND MAKE A GRINDING SOUND. IT WILL WORK OFF AND ON FOR A PERIOD OF TIME AND THEN START THE NOISE AGAIN AND THE FLASHING WHERE THE MAGNITORN UINT IS LOCATED ON THE SIDE OF THE UNIT. CAN THIS BE THE MAGNITRON UNIT OR THE HV TRANSFORMER?
  • 78 Answers
It could be a magnetron sparks to the open metal inside the m/w cavity or some broken wire on high voltage side. It is not HV transformer (when burn create a lot of smoke and bad smell). Magnetron needs to be replace.
Posted on Dec 03, 2008
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
When running the noise sounds like the fan is not working correctly.
when microwave is running the fan sounds like it is grinding
Feb 03, 2013 | GE JVM3670 Microwave Oven
Whirlpool mircowave making grinding noise
The grinding noise could be from the turntable motor, or the fan. Remove plate from oven and put a cup of cold water in, set for 30 seconds and run the microwave, if no grinding is detected it means the turntable motor is near end of life. If there is no change unplug microwave and remove top check the fan mounts tighten if loose, if straps are tight suspect the fan motor.
Jun 11, 2012 | Whirlpool Microwave Ovens
I replaced the cooktop lightbulb in my Radarange Amana Mircowave. When I turned the light on there was a loud pop and the breaker flipped. I took the bulb back out(which was now blown) and flipped the...
Yes there are fuses inside.
There are lethal voltages within Microwave ovens that can stay charged up for many days. If you do not understand the hazards, get it repaired by a qualified electrician.
Dec 02, 2017 | Amana Radarange Microwave Oven
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Jul 12, 2009 | Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Model #mh7130xe made grinding noise then in line fuse blew
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 05, 2008 | Whirlpool MH7130XE Microwave Oven
Help, my mircowave
It may have a short, if i were you i wouldn't be using it check to see if your mircowave is on a recall list if its not and your mircowave is under warranty see if you can replace it with a new one
Feb 18, 2008 | Microwave Ovens
Whirlpool GT1195SH Microwave Oven Logo
354 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
