Question about Sony 1GB Memory Stick PRO Duo Memory Card
HI! can i ask,my mother board supports only 400 and 533mhz but when i put 1g pc800 it will run.my question is, is there any problem about that?or any conflict about speed. or it may continue normaly because of backward compatibility.I'm greatful to hear your advice.thanks!danz
    Problem Solver:
  • 15 Answers
The speed readings on your memory are the maximum speed that that memory can preform at. When you have different speed memory put in your computer it will run at the speed of the memory which is the slowest. i.e. you might have a pc800 but that baby's only running at 400 mhz or 533mhz.
Posted on Dec 03, 2008
Whats max RDRAM I can install on A49507-903 ?
2GB.
The Intel Desktop Board D850GB has four RIMM sockets (two sockets for each channel) and supports the following memory features:
Single- or double-sided RIMM configurations
Maximum of 32 Direct Rambus devices per channel
Total system memory configurations from 128 MB (minimum) to 2 GB (maximum) utilizing 128/144 Mbit or 256/288 Mbit technology PC600 or PC800 compliant RDRAM
Serial Presence Detect (SPD) based configuration for optimal memory operation
Suspend to RAM support
ECC and non-ECC support
When installing memory, note the following:
The four RIMM sockets are grouped into two banks:
Bank 0 (labeled on the board as RIMM1 and RIMM2)
Bank 1 (labeled on the board as RIMM3 and RIMM4)
Bank 0 must be populated first ensuring that the RDRAM installed in RIMM1 and RIMM2 is identical in speed, size, and density. For example, the minimum system configuration would use two 64 MB RIMM modules of PC600 or PC800 RDRAM.
If the desired memory configuration has been achieved by populating Bank 0, then Bank 1 should be filled with two Continuity RIMMs.
If memory is to be installed in Bank 1, the RIMM modules installed in RIMM3 and RIMM4 must be identical in size and density to each other, and match the speed of the RIMM modules in Bank 0. The RIMM modules do not, however, need to match those in Bank 0 in size and density. For example, if Bank 0 has two 128 MB RIMMs of PC800 RDRAM, Bank 1 would require PC800 RDRAM also, however, any other supported RIMM modules such as 64 MB or 192 MB could be used.
If ECC functionality is required, all installed RIMM modules must be ECC-compliant.
Jun 08, 2012 | Computers & Internet
Which RAM is suitable for Intel presscott 533 motherboard for upgradation
The Mother board only supports DDR1 333mhz or 400mhz
Maximum size of memory the board can read is 2gb in total
I would suggest upgrading to at least a DDR2 Motherboard
May 27, 2011 | Intel Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
I have an abit kd7 raid mother board and just installed 3 1g sticks of pc3200 400mhz and the bios only reads up to 266 any help
Is the board rated for the faster speed? Just putting in faster chips will not work unless the motherboard supports that speed.
Mar 26, 2010 | Abit KD7-RAID Motherboard
Hi I have a mother board EP-4T2A3 and it supports
This EP-4T2A3 is unique, that the can only utilize the slightly more expensive RDRAM memory modules. Furthermore, because of the dual memory controllers in the i850 chip-set, all motherboards based off of this chip-set must also have its RDRAM installed in pairs. You can purchase RAMBUS chips of PC600 to PC800 memory modules. You have 4 RIMM slots, and they must be installed in pairs, or you will get speeds of only a single module. The unfortunate part is that the RDRAM modules are a little more pricey. You can find some samples of these HERE.
Good Luck
Mark
Dec 29, 2009 | EPoX EP-4T2A3 Motherboard
Memory limit for my dell E139761 motherboard
Although the motherboard ultimately decides how much memory your system can handle, Dell does not list the specifications of motherboards. You need the model number of the computer, and if the motherboard is not the original one that came in the computer when it was built by Dell they won't know either.
You can go to dell.com and put in your service tag to see the specifications yourself. If you post the computer model number or service tag here that's what someone else will do anyway.
Mar 23, 2009 | Dell Computers & Internet
¿Could it work with 2 Cards RAM of 1G/800? ¿Could PC work with this mother board and 2 Cards RAM of 1G/800?
That's a pretty big jumb from 667 to 800MHz. (Motherboard does not support 800MHz).
Manual says:
This motherboard accommodates two memory modules. It can support two 240-pin
DDR2 667/533/400. The total memory capacity is 2 GB.
Yet, ECS web site says it supports up to 4 GB.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
BIOS for 945GCT-M/1333 (PCB:3.x) version 08/07/18 does not include information pertaining to increased memory speed up to 800MHz. (Bios link).
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Bios&MenuID=44&LanID=0
Mike
Nov 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
Why MIS P4M900M3 couldn't support 1GB ,2GB RAM when they are together?
You can't use two different size at a time, they must be of same size. If you will use two sims both of 2G then it will work, either you can use both of 1G.
There is no problem no your motherboard niether in SIMs.
Thanks
iqbal
Mar 16, 2008 | Intel Motherboard
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
Sony 1GB Memory Stick PRO Duo Memory Card Logo
67 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
