Question about Husqvarna Chain Saw 20" Bar
Husqvarna 359 Low speed running
I have a Husqvarna 359 saw which I purchased online about 3 years ago. As
for use, I am just about through the first chain.
The last two times that I have used the saw I noticed that after about 5
minutes of running the motor would not stay running at a low speed. Say
something less then 50% throttle. To get it started required choking at
about 50%.
Below is what I have done to date.
The last time I used it I checked the jet settings and adjusted the high
speed to its max open, to no avail.
Stopping the saw for 5 to 10 minutes restores it to a normal state. It
will start up and idle.
I started out to remove the carburetor until I figured out it appeared to
be a major effort. I did remove the top cover to the pumping diaphragm
and every thing looked good there. Same for the fuel hose in the tank,
looks good. But still the same problem. Saw runs strong for the first
few minutes.
Having thought this through a bit more it would appear to me that its a
fuel delivery problem. Which for me means a diaphragm, hose or seal on
the crank case. But again I was after a quick fix looking for debris in
the carburetor jets, and still would be if I can figure an easy way to
remove it, just because its easy to do compare to the rest.
Any thoughts?
  • wrvyn Feb 25, 2009
    I have two 359 husquvarna's and after their first year are having the same issue. They are hard to start, and then after mere moments die if not throttled or choked. I rebuilt the carb on one thinking maybe the needle valve was sticking or one of the diaphrams were damaged, also flushed the tank, changed the fuel filter and the fuel line. Now it starts but spits fuel out either the compression release or the muffler???? My brother has one as well that did the same thing. I am running out of ideas!
  • dutchcreek Mar 20, 2009
    I have a Husqvarna 359 that was starting hard, then would not idle. I tried new fuel and air filters and fuel line as it obviously was not getting fuel. Took it to the dealer and he said it has "lean seize" and a ruined piston and cylinder. This on a saw that has ALWAYS run on husqvarna oil and the proper gasoline with less than 100 hours on it. It is 18 months old and he is refusing to do anything warranty wise-even though any of the other causes of "lean sieze" would be crankshaft seals, or other seals making it run lean-and there is no reason these shouyld be bad on this new of a saw.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
A lot of 2 cycle engines do not run very well if they have been put up for a long period, (say for winter) with gas in the engine and carb. I finally learned the hard way that if you empty the gas tank and start the normal way and use up the fuel in the lines and carb, you don't get the residue build up from gas that has deteriorated over time.
Suggestion: empty the fuel out of the tank and run it dry by starting. g\
Get some gas stabilizer and add to fresh gas, fill the tank and run a few times. It will take awhile but you can gradually get rid of any residue build up
Hope this helps. Loringh ps Please leave a rating if appropriate Thanks
Posted on Dec 03, 2008
Read a number of posts on arborsite that this problem likely stems from the clamp holding on the carburetor. Clamp is plastic and stretches over time causing a air leak, Understand they recalled this part and have replaced with a more traditional metal clamp.
Posted on Jun 03, 2010
Check your in tank filter. There could be debris in the tank. Running for 5 to 10 min. could draw the debris to the filter and clogging it and letting it sit for a little while could let the debris settle. Just a thought.
Good luck
Posted on Jan 15, 2009
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
I have a Husqvarna 357 xp which is about a year and a half old, but has had very little use for a professional saw. I was cutting with the saw upside down when it suddenly cut out. After letting it rest...
The carb is an "all position" type and shouldn't be the problem.
Check and clean/replace the fuel filter in the tank. Dirty or old gas, sawdust and/or water etc. settle on the bottom of the tank; and when the saw is turned over will plug the filter, causing the symptoms you discribe.
It is possible, if you used old gas(3 to 6 months) that small varnish particles have gotten through the fuel filter and have pluged the fine screen in the carb(located under the diaphram).
Sep 22, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I need to know how to adjust the bar oiler on my husqvarna chainsaw
A link to an OM for a 2005 Husqvarna 357XP/359 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
The procedure is on page 35.
CAUTION: It only has 3 positions; forcing it beyond the stops may render it inoperative.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
Husqvarna 359: Has run fine for 3 years. Now when first starting idles fine but as soon as it warms up idle speed increases enough to continually engage the clutch. Carb. setting have never been changed...
I think an air leak and she is running lean. Maybe time for some pressure/vacuum testing. Continuing to tweak the carburetor may camouflage a larger problem until the saw fails.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Husqvarna Chain Saw 20" Bar
Looking at buying a Husqvarna 55 Special pro. The serial number is 1998 8510004. The seller tells me he bought it in the 2000s, is it true.
Ask to see the sales receipt if you are in need of proof of purchase date. Even contacting Husqvarna to ask when it was registered may not be the actual purchase date. I saw a question not long ago about a saw that was purchased new that had been out of production for a couple of years. It is possible it sat on a dealer's shelf for a period.
Looking at the serial, it was manufactured in 1998, the 51st week (Dec), and was the 4th product that week.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit year please contact Husqvarna for clarification)
15 = week produced – March
00198 = 198th unit Husky produced that week
Lou
Feb 28, 2010 | Husqvarna 450 e-series 18" Chain Saw
Hard to start.
My Husky 359 workshop manual says on Appendix A (USA) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles.
There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move". I wager your manual would be similar.
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I hope you found this post helpful.
Lou
Jan 17, 2010 | Husqvarna Chain Saw 20" Bar
I have a used husqvarna 455 what size scrench do i need
You can find both an Operator's Manual and an Illustrated Parts List for your saw here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
Take your saw with you and stop by a local saw shop (regardless of brand). Odds are good they have the correct scrench and it will cost the same without the shipping charges.
My 359 scrench is 13 & 19 mm. HTH
Lou
Nov 04, 2009 | Husqvarna Chain Saw 20" Bar
Bar oil leaks when saw not in use
What you describe is common in many chainsaws. Try loosening then reseating the oil cap before putting her away to relieve any pressure built up in the oil tank. Check all the hose connections.
HusqvarnaUSA.com
Enter the 3 digit model number of you saw; uncheck "Manuals"; Check “Illustrated parts lists ”; then search.
Serial number breakdown: 06 1500198 (Husqvarna 359)
06 = year produced (prior to 2000 there is no space and only the first digit is used (61500198 could be 86 or 96))
15 = week in 2006 it was produced (March)
00198 = 198th unit produced that week regardless of model or type
Sep 24, 2009 | Husqvarna Chain Saw 20" Bar
What should compression be on husky 359?
This saw needs aproxamitly 150 psi. Any less than 120 and you will have problems with the saw breaking up at high rpm and stalling under load. Pop the muffler off and take a peek at the piston and the cylinder walls for scoring. If its scored it will need a new jug and piston, the kit from Husqvarna, includes everything you will need, should run from $175.00 to $200.00. Hit us up on eBay MorganPower is our user name. http://www.morganpower.com/ is our website. Or you can email me at ebay@morganpower.com
Hope this helps, feel free to email me with any other questions, we are a Husqvarna dealer/repair center and can help you out with that saw. It is a great saw all the features of the XP line at a fraction of the cost. It has the 3 piece crank and magnesium case. It is definitely worth putting the money into this saw!
-Steve
Apr 07, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 136 chain saw
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Jan 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
1,576 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
