Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer not working properly
After a recent move by professionals (who were very careful) our side by side fridge won't keep meat frozen after 24 hrs of being plugged in. Have any ideas as to what could be wrong?
Thanks,
    Scholar:
  • 82 Answers
Sometimes when movers use dollies to move a frig they will put it underneath the condenser fan motor and bend the housing into the fan blade. If this fan doesn't turn, the compressor will turn off on the heat sensing overload before it has a chance to cool everything inside.
Posted on Dec 03, 2008
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have moved my bush fridge freezer bsbm166s and now the light is on but its not working
If you have laid it down when you moved it you need to have it in the upright position for 24 hrs. before plugging it in. (so unplug it. let it sit for 24 hrs. then plug it in.)
Sep 20, 2013 | Freezers
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Ice maker not dumping ice
Hi: Not knowing how long it's been hooked up... Ice production can take as long as 72 hrs to start. Usually 24 to 48 hrs. The freezer also has to be stable at 0 degrees F to start producing ice. The tray mab be full but it wont dump untill 0 degrees F. Another thing is it's human nature to keep opening the freezer to see if Ice has been made. This justs dumps the cold air out and will slow the ice production. Just because your food is frozen dosn't mean it is at 0 degrees F. Ice cream should be rock hard. Try setting your freezer colder and allow 24 hrs for it to stabilize. This is the best try and it usually works, before calling a tech. I hope this helps, Jeff
Jun 07, 2009 | Hotpoint HSS25GFP Side by Side...
Not keeping meat completely frozen.
the seal around the freezer is always hot, that prevent humidity around the seals and avoid it gets wet, now u have to check the low pressure side of ur refrigerator just to be sure that ur refrigerator is not running low r134 charge, try to use a brush to clean the condenser unit in the back of ur refrigerator and clean the coils... otherwise i suggest to call a technician !
Mar 15, 2009 | Hotpoint HSS25GFP Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
